Category Top
Optional Equipment and System Requirements
Printing or Sending a Fax from a Computer
Using E-Mail/I-Fax
Sending Data
Checking Your Network Environment
Network Environment Setup Procedures
Connecting the Machine to a Computer or Network
Specifying Network Settings from the Touch Panel Display
Interface Settings
Communication Environment Setup
IEEE802.1X Authentication Settings
Selecting the IEEE802.1X Authentication Method
TCP/IP Network Setup Procedures
Protocol Settings
TCP/IPv4 Settings
TCP/IPv6 Settings
Settings Common to TCP/IPv4 and TCP/IPv6
Confirming TCP/IPv4 Settings (PING Command)
Confirming TCP/IPv6 Settings (PING Command)
Setting the Key Pair Used With SSL Encrypted Communications
IPSec Settings
Registering a Security Policy
Editing a Security Policy
Startup Time Settings
Setting Up a Computer for Printing/Sending a Fax
Printer Connection Method (LPD/Raw)
Windows 2000/XP/Server 2003/Server 2008/Vista/7/Server 2008 R2
Mac OS X 10.3.9 or Later
UNIX
Printer Connection Method (IPP/IPPS)
Printer Connection Method (FTP)
Printer Connection Method (WSD)
Setting Up a Computer as a File Server
FTP Server Settings
WebDAV Server Settings
NetWare Network Setup Procedures
NetWare Print Service Settings
Setup Using NetWare Administrator or PCONSOLE
Protocol Settings
SMB/CIFS Network Setup Procedures
Protocol Settings
Connecting to a TCP/IP Network
Connecting to an SMB/CIFS Network
Connecting to an SMB/CIFS Network and Configuring a Shared Folder
AppleTalk Network Setup Procedures
Protocol Settings
Network Connection Problems and Remedies
Printing Problems and Remedies
Data Sending/File Sharing Problems and Remedies
Encrypted SSL Data Communication Problems and Remedies
Confirming Settings
Checking the Block Log
Obtaining the Public Key of the Machine to Use SSL with Windows Server 2008/Vista/7/Server 2008 R2
Top » Network » Checking the Block Log
08KE-1W4
When IP addresses have been set so that data transmission and reception with the machine is denied, and data transmission and reception is attempted between the machine and the devices having those IP addresses, a block log is recorded. In addition, a block log for IP addresses and port numbers is recorded when transmitting data.
The procedure for referring to the block log is described below.
The procedure for setting IP addresses that are to be allowed/denied data transmission/reception with the machine is described in steps 13 to 16 of "TCP/IPv4 Settings," and steps 9 to 11 of "TCP/IPv6 Settings."
Press [Preferences] → [Network] → [Firewall Settings].
Press [IP Address Block Log].
Up to 100 block logs can be displayed.
You can export the block log to a CSV format file, using the Remote UI.
