Category Top
Optional Equipment and System Requirements
Printing or Sending a Fax from a Computer
Using E-Mail/I-Fax
Sending Data
Checking Your Network Environment
Network Environment Setup Procedures
Connecting the Machine to a Computer or Network
Specifying Network Settings from the Touch Panel Display
Interface Settings
Communication Environment Setup
IEEE802.1X Authentication Settings
Selecting the IEEE802.1X Authentication Method
TCP/IP Network Setup Procedures
Protocol Settings
TCP/IPv4 Settings
TCP/IPv6 Settings
Settings Common to TCP/IPv4 and TCP/IPv6
Confirming TCP/IPv4 Settings (PING Command)
Confirming TCP/IPv6 Settings (PING Command)
Setting the Key Pair Used With SSL Encrypted Communications
IPSec Settings
Registering a Security Policy
Editing a Security Policy
Startup Time Settings
Setting Up a Computer for Printing/Sending a Fax
Printer Connection Method (LPD/Raw)
Windows 2000/XP/Server 2003/Server 2008/Vista/7/Server 2008 R2
Mac OS X 10.3.9 or Later
UNIX
Printer Connection Method (IPP/IPPS)
Printer Connection Method (FTP)
Printer Connection Method (WSD)
Setting Up a Computer as a File Server
FTP Server Settings
WebDAV Server Settings
NetWare Network Setup Procedures
NetWare Print Service Settings
Setup Using NetWare Administrator or PCONSOLE
Protocol Settings
SMB/CIFS Network Setup Procedures
Protocol Settings
Connecting to a TCP/IP Network
Connecting to an SMB/CIFS Network
Connecting to an SMB/CIFS Network and Configuring a Shared Folder
AppleTalk Network Setup Procedures
Protocol Settings
Network Connection Problems and Remedies
Printing Problems and Remedies
Data Sending/File Sharing Problems and Remedies
Encrypted SSL Data Communication Problems and Remedies
Confirming Settings
Checking the Block Log
Obtaining the Public Key of the Machine to Use SSL with Windows Server 2008/Vista/7/Server 2008 R2
Top » Network » AppleTalk Network Setup Procedures » Protocol Settings
Protocol Settings
08KE-1UW
This section describes how to specify the protocol settings for the machine using the control panel. If you are configuring the settings for the first time, use the control panel of the machine.
After configuring the settings, you can change them using software other than the control panel of the machine. For more information, see "Settings/Registration Table."
Press [Preferences] → [Network] → [AppleTalk Settings].
Press [On] for <Use AppleTalk> → specify the following items → press [OK].
Press [Off] for <Use AppleTalk> if you do not want to use AppleTalk.
To set the printer name displayed on the printer screen of the Macintosh, press [Service Name]. Enter a name for the printer → press [OK].
If a zone is set in your network environment, set the zone name. Press [Zone]. Enter the zone name → press [OK].
If you want to use the PS printer driver with the PS Printer Kit, set whether to apply spooling to the print job.
[Spool] for <Print Mode>: The machine specified in [Service Name] prints only after spooling the print job to the machine' s hard disk. If you entered "Printer1" for [Service Name] and select [Spool] for <Print Mode>, "Printer1_S" is displayed on the Macintosh printer screen.
[Direct] for <Print Mode>: The machine specified in [Service Name] prints without spooling the print job to the machine' s hard disk. If you entered "Printer2" for [Service Name] and select [Direct] for <Print Mode>, "Printer2_D" is displayed on the Macintosh printer screen.
[Both] for <Print Mode>: The machine specified in [Service Name] prints either with or without spooling the print job to the machine' s hard disk. If you entered "Printer3" for [Service Name] and select [Both] for <Print Mode>, "Printer3_S" and "Printer3_D" are displayed on the Macintosh printer screen. Therefore, you can select whether to spool the print job on the Macintosh printer screen each time you print.
If you set <Use AppleTalk> to 'On', the machine will not completely enter the Sleep mode.
If there is more than one printer in the same zone, each printer must have a unique name.
You can also enter a zone name by pressing [Browse] and selecting the appropriate name from the displayed list.
Depending on the machine you are using, you may have to use optional equipment to print via an AppleTalk network. For information on the optional products required, see "Optional Equipment and System Requirements."
