Network Environment Setup Procedures
08KE-1S0
Before using the machine in a network environment, it is necessary to perform the following setup procedures.
Connect the machine to the network using the network cables.
Specify the interface settings for communication between the machine and computers on your network. To specify the settings, use one of the following:
The machine's control panel
The Remote UI (via a Web browser)
Set up the environment for communication between the machine and computers on your network.
Specify the settings of IEEE802.1X authentication.
If you are using the imagePASS, see the manual provided with the imagePASS.
If you are using the imagePASS, some functions are not available with this machine. For details, see the manual provided with the imagePASS.
