Top » Before You Start Using This Machine » Installing the Machine » Loading Paper into the Paper Drawer
0C1Y-00H
This section describes how to load plain paper into the paper drawer. If you load paper other than plain paper such as recycled paper, specify the type of paper loaded into the paper drawer. (See "Registering the Paper Size and Type for a Paper Source.")
Press the open button on the paper drawer.
Grip the handle, and pull out the paper drawer until it stops.
Squeeze the lever on the side guide. Without releasing the lever, slide the side guide leftward or rightward to align it with the mark for the desired paper size.
*1: Lever
*2: Slide Guide
4.
Squeeze the lever on the front guide. Without releasing the lever, slide the front guide backward or forward to align it with the mark for the desired paper size.
*1: Lever
*2: Front Guide
5.
Before loading paper, always fan the sheets several times and align the edges to facilitate feeding.
6.
Load the paper stack into the paper drawer.
CAUTION
When handling paper, take care not to cut your hands on the edges of the paper.
Information on the paper loaded here will be registered later in the Setup Guide.
7.
Gently push the paper drawer back into the machine until it clicks into place in the closed position.
CAUTION
When returning the paper drawer to its original position, be careful not to get your fingers caught, as this may result in personal injury.
8.
Peel off the label for the loaded paper size and affix the label to the part of the paper drawer indicated in the illustration.
