Installing the Toner Cartridge
0C1Y-00F
Turn the toner cartridge lock lever counterclockwise so that the arrow marks on the lever and its axis face each other.
*1: Toner Container Lock Lever
Remove the toner cartridge from its protective bag.
Remove the protective cap.
Do not touch the tip of the toner cartridge or subject it to shock by hitting it. Doing so may cause the toner cartridge to leak.
4.
Insert the toner cartridge into the machine as far as it will go.
Support the toner cartridge with one hand from underneath while pushing it into the machine with the other hand.
5.
Turn the toner cartridge lock lever clockwise so that the arrow marks on the lever and its axis face each other.
6.
Close the front cover.
1.Close the front cover of the main unit.
2.Lower the control panel back in place.
 CAUTION
Be careful not to get your fingers caught, as this may result in personal injury.
