e-Manual
Top
Site map
Help
Glossary
Contents
Search
Previous
Next
Print this topic
Category:
Before You Start Using This Machine
Flow of Settings
Basic Operations
Optional Products/Software
Settings/Registration
Maintenance
Problem Solving
Copy
Fax
Scan and Send
Scan and Store
Access Stored Files
Fax/I-Fax Inbox
Secure Print
Web Access
Scanner
Quick Menu
Status Monitor/Cancel
Print
Network
Remote UI
MEAP
Security
Practical Workflows
How to Use This Manual
Expand all
Collapse all
Category Top
Installation Location and Handling
Installation Precautions
Handling Precautions
Backing Up/Exporting Data
Parts and Their Functions
Main Power and Energy Saver Key
Installing the Machine
Items Included with the Machine
Carrying the Machine to the Installation Site and Removing the Packing Materials
Installing the Filters
Attaching the Duplex Tray and the Tray Rib
Installing the Drum Unit
Installing the Toner Cartridge
Loading Paper into the Paper Drawer
Attaching the Precaution Label
Connecting the Power Cord
Using the Setup Guide to Configure the Machine
Print all
Keyword:
Search options
Search all categories
Search from below categories
Flow of Settings
Basic Operations
Maintenance
Problem Solving
Copy
Fax
Scan and Send
Scan and Store
Access Stored Files
Fax/I-Fax Inbox
Secure Print
Web Access
Scanner
Quick Menu
Print
Network
Remote UI
MEAP
Security
Practical Workflows
Case sensitive
Differentiate between one-byte and two-byte
Search with these conditions
Specify search conditions
Search Method
Top
0C1Y-00K
For Users with the Optional Finisher:
See the installation manual supplied with the optional finisher to attach the finisher to the machine, then connect the power cord.
Connect the power cord to the socket on the left side of the machine and to the wall outlet.
Back to Top
