Registering the Paper Size and Type for a Paper Source
You can register the paper size and type for each paper source. This setting enables you to achieve the appropriate print results.
Be sure to correctly set the paper type. If the type of paper is not set correctly, it could adversely affect the quality of the image. Moreover, the fixing unit may become dirty and require a service repair, or the paper could jam.
Load paper in the paper source.
For more information on the available paper for each paper sources, see "Available Paper Stock."
For more information on how to load paper, see "Loading Paper."
Press [Preferences] → [Paper Settings] → [Paper Settings].
4.
Check whether the same paper size as the paper that is loaded is displayed in the paper source buttons.
The numbers on the screen represent the following paper sources:
Staple Finisher-R1 and Cassette Module-AA1 are attached.
If you load standard size paper:
If you load custom size paper:
If you load envelopes:
Check if the displayed paper size, which is detected automatically, is correct.
If the displayed paper size is different from the loaded paper size, paper may not be loaded properly. For more information on loading paper, see "Loading Paper."
If [Custom] is displayed as the paper size when you load standard sized paper, press [Custom Size] → [Cancel Set.]. The proper paper size will be detected automatically and displayed on the screen.
Select the button for the paper source in which you loaded paper → press [Custom Size].
Enter the paper size → press [OK].
You can select a button ([S1] to [S4]) containing a stored paper size setting, instead of entering values.
With the envelope cassette attached to the machine, select Paper Drawer 2 → press [Envelope].
Select the envelope type → press [OK].
5.
Select the paper source that you want to register the paper size for → press [Set].
6.
Select the same paper type as the one you loaded → press [OK] → [OK].
If you select [Plain], select the paper weight from [Plain Paper Weight Set.].
You can select the paper type from the simple or detailed setting screen. For paper types that are not displayed on the simple setting screen, press [Detailed Settings] → select the paper type from the detailed setting screen.
Simple Settings Screen
Detailed Settings Screen
You can register paper types if paper types for the loaded paper are not displayed on the detailed setting list. For instructions on registering paper types, see "Registering/Editing Custom Paper Types."
Paper sizes and types can also be registered from the Consumable screen.(See "Checking the Status of Consumables and Other Information.")
» Settings/Registration » Preferences » Paper Settings » Registering the Paper Size and Type for a Paper Source
0C1Y-053
