Top » Before You Start Using This Machine » Installing the Machine » Attaching the Duplex Tray and the Tray Rib
0C1Y-00C
If you are attaching the optional Staple Finisher-R1 to the machine, the following steps are not necessary. Proceed to the next section, "Installing the Drum Unit."
Lift the control panel.
Attach the duplex tray by inserting its tabs into the slots on the machine.
Be careful not to accidentally insert the tabs into the slot circled in the illustration.
Insert the front tabs of the tray rib into the slots first and then press down on its left end so that the rear tabs snap into the slots.
4.
Lower the control panel back in place.
