Category Top
Optional Equipment and System Requirements
Printing or Sending a Fax from a Computer
Using E-Mail/I-Fax
Sending Data
Checking Your Network Environment
Network Environment Setup Procedures
Connecting the Machine to a Computer or Network
Specifying Network Settings from the Touch Panel Display
Interface Settings
Communication Environment Setup
IEEE802.1X Authentication Settings
Selecting the IEEE802.1X Authentication Method
TCP/IP Network Setup Procedures
Protocol Settings
TCP/IPv4 Settings
TCP/IPv6 Settings
Settings Common to TCP/IPv4 and TCP/IPv6
Confirming TCP/IPv4 Settings (PING Command)
Confirming TCP/IPv6 Settings (PING Command)
Setting the Key Pair Used With SSL Encrypted Communications
IPSec Settings
Registering a Security Policy
Editing a Security Policy
Startup Time Settings
Setting Up a Computer for Printing/Sending a Fax
Printer Connection Method (LPD/Raw)
Windows XP/Server 2003/Server 2008/Vista/7/Server 2008 R2/8/Server 2012
Mac OS X 10.5 - 10.8
UNIX
Printer Connection Method (IPP/IPPS)
Printer Connection Method (FTP)
Printer Connection Method (WSD)
Setting Up a Computer as a File Server
FTP Server Settings
WebDAV Server Settings
NetWare Network Setup Procedures
NetWare Print Service Settings
Setup Using NetWare Administrator or PCONSOLE
Protocol Settings
SMB/CIFS Network Setup Procedures
Protocol Settings
Connecting to a TCP/IP Network
Connecting to an SMB/CIFS Network and Configuring a Shared Folder
Network Connection Problems and Remedies
Printing Problems and Remedies
Data Sending/File Sharing Problems and Remedies
Encrypted SSL Data Communication Problems and Remedies
Confirming Settings
Checking the Block Log
Obtaining the Public Key of the Machine to Use SSL with Windows Server 2008/Vista/7/Server 2008 R2/8/Server 2012
Top » Network » Encrypted SSL Data Communication Problems and Remedies
0C1Y-1F3
This section describes how to resolve encrypted SSL data communication problems.
You Cannot Use Encrypted SSL Communication for IPP Printing, E-mail/I-Fax, the Remote UI, MEAP Functions via a Web Browser, and Device Information Delivery, or Confirm Department IDs and PINs Even after You Have Turned SSL On.
Cause 1
The generated key pair or server certificate is corrupted.
Remedy
After erasing the key pair you are using, generate a key pair and server certificate.
For instructions on how to confirm whether the key pair you are using is corrupted, see "Editing Key Pairs and Server Certificates."
Cause 2
The preinstalled default key pair or server certificate is corrupted.
Remedy
Cause 3
The registered key pair file or server certificate file is corrupted.
Remedy
After erasing the key pair you are using, install the key pair file and server certificate file created on your computer using the Remote UI. (See "Installing a Key Pair File and Server Certificate.") Then, register the installed files on the control panel of the machine.
