Setting Up a Computer for Printing/Sending a Fax
0C1Y-1E3
After you have completed the protocol settings for printing and sending a fax with the machine, you are ready to set up each of the computers for printing or sending a fax.
Connecting to a TCP/IP Network
All computers that use the printer must have TCP/IP client software installed and must be enabled for TCP/IP network use. For details, see the manuals provided with your operating system.
Installing the Driver and Specifying the Port Setting
To print or send a fax from a computer, you must install a driver and specify a port setting. The port setting differs depending on the print application used for printing or sending a fax. Use the following information as a guide to determine the print application you are using, and then perform the necessary operations.
LPD
This is the print application generally used with TCP/IP.
(See "Printer Connection Method (LPD/Raw).")
Raw
This is a print application used with Windows. It can send a job to the machine at higher speeds than LPD.
IPP/IPPS
This is a print application that can be used with TCP/IP.
IPP enables you to use the HTTP protocol to send data to a machine on an intranet/the internet.
IPPS is a print application which performs encrypted SSL communication when using IPP.
(See "Printer Connection Method (IPP/IPPS).")
FTP
This is a print application that prints files by copying them to the printer using FTP client software.
(See "Printer Connection Method (FTP).")
WSD
This is a print application that can be used with Windows Vista/Server 2008/7/Server 2008 R2/8/Server 2012.
(See "Printer Connection Method (WSD).")
If the IP address of the computer in which the driver is installed has not already been given transmission and reception permission in [Firewall Settings] on the Network screen of the machine, print and fax jobs cannot be sent from the computer. (See steps 13 to 16 in "TCP/IPv4 Settings," or steps 9 to 11 in "TCP/IPv6 Settings.")
If you print with IPP, the [Pause Printing] and [Cancel All Documents] settings on the [Printers]/[Printer] menu in the Windows print queue cannot be used. You can display the print queue by double-clicking the icon for the machine that appears by following the procedure below.
Windows XP Professional/Server 2003: From the [Start] menu, select [Printers and Faxes].
Windows XP Home Edition: From the [Start] menu, select [Control Panel] - [Printers and Other Hardware] - [Printers and Faxes].
Windows Vista: From the [Start] menu, select [Control Panel] → double-click [Printers].
Windows Server 2008: From the [Start] menu, select [Control Panel] → double-click [Printer].
Windows 7/Server 2008 R2: From the [Start] menu, select [Control Panel] → [View devices and printers] for [Hardware and Sound].
Windows 8/Server 2012: Place the cursor on the top right (bottom right) of the desktop → select [Settings] → [Control Panel] → [Devices and Printers] for [Hardware and Sound]/[Hardware].
