Category Top
Optional Equipment and System Requirements
Printing or Sending a Fax from a Computer
Using E-Mail/I-Fax
Sending Data
Checking Your Network Environment
Network Environment Setup Procedures
Connecting the Machine to a Computer or Network
Specifying Network Settings from the Touch Panel Display
Interface Settings
Communication Environment Setup
IEEE802.1X Authentication Settings
Selecting the IEEE802.1X Authentication Method
TCP/IP Network Setup Procedures
Protocol Settings
TCP/IPv4 Settings
TCP/IPv6 Settings
Settings Common to TCP/IPv4 and TCP/IPv6
Confirming TCP/IPv4 Settings (PING Command)
Confirming TCP/IPv6 Settings (PING Command)
Setting the Key Pair Used With SSL Encrypted Communications
IPSec Settings
Registering a Security Policy
Editing a Security Policy
Startup Time Settings
Setting Up a Computer for Printing/Sending a Fax
Printer Connection Method (LPD/Raw)
Windows XP/Server 2003/Server 2008/Vista/7/Server 2008 R2/8/Server 2012
Mac OS X 10.5 - 10.8
UNIX
Printer Connection Method (IPP/IPPS)
Printer Connection Method (FTP)
Printer Connection Method (WSD)
Setting Up a Computer as a File Server
FTP Server Settings
WebDAV Server Settings
NetWare Network Setup Procedures
NetWare Print Service Settings
Setup Using NetWare Administrator or PCONSOLE
Protocol Settings
SMB/CIFS Network Setup Procedures
Protocol Settings
Connecting to a TCP/IP Network
Connecting to an SMB/CIFS Network and Configuring a Shared Folder
Network Connection Problems and Remedies
Printing Problems and Remedies
Data Sending/File Sharing Problems and Remedies
Encrypted SSL Data Communication Problems and Remedies
Confirming Settings
Checking the Block Log
Obtaining the Public Key of the Machine to Use SSL with Windows Server 2008/Vista/7/Server 2008 R2/8/Server 2012
Top » Network » Network Environment Setup Procedures » IEEE802.1X Authentication Settings
0C1Y-1CF
This section describes how to set IEEE802.1X authentication.
For IEEE802.1X, the RADIUS server requires user authentication from the supplicant (the machine) when connecting to a network. EAPOL (EAP over LAN) is used for communication between the supplicant and the authenticator (LAN switch) that performs access control of the terminal based on the authentication results. Authentication information is managed collectively with the RADIUS (Remote Authentication Dial In User Service) server, and then the supplicant is authenticated. Invalid access can be prevented because this authentication method permits only supplicants authenticated by the RADIUS server to connect to the network via an authenticator. The authenticator blocks communication from supplicants not authenticated by the RADIUS server.
The machine supports the following methods of authentications:
EAP-TLS (Extensible Authentication Protocol-Transport Level Security)
For the EAP-TLS method, authentication is performed by issuing a digital certificate bilaterally to both the client and the RADIUS server. The key pair and client certificate sent from the machine are verified using the CA certificate on the RADIUS server. The server certificate sent from the RADIUS server is verified using the CA certificate on the client (the machine). The CA certificate used to verify the server certificate must be registered. For information on installing the CA certificate file using the Remote UI, see "Installing a CA Certificate File." For instructions on registering the installed CA certificate file, see "Registering/Editing a CA Certificate File."
Also, the settings for the user login name (to be authenticated by IEEE802.1X authentication), as well as the settings for the key pair (in PKCS#12 format) and the client certificate, are necessary to use EAP-TLS with the machine. After installing the key pair file and client certificate file using the Remote UI (see "Installing a Key Pair File and Server Certificate"), set the key pair and client certificate for EAP-TLS as the default key with the control panel of the machine.
EAP-TTLS (EAP-Tunneled TLS)
For the EAP-TTLS method, only the RADIUS server issues a digital certificate. The server certificate sent from the RADIUS server is verified using the CA certificate on the client. The CA certificate used to verify the server certificate must be registered. For information on installing the CA certificate file using the Remote UI, see "Installing a CA Certificate File." For instructions on registering the installed CA certificate file, see "Registering/Editing a CA Certificate File."
Furthermore, the name of the user/login user to be authenticated with IEEE802.1X authentication and the password need to be set to use EAP-TTLS with the machine.
The user can select two types of internal authentication protocol supported by EAP-TTLS: MS-CHAPv2 (Microsoft Challenge Handshake Authentication Protocol Version 2), or PAP (Password Authentication Protocol). You cannot set both MS-CHAPv2 and PAP simultaneously.
PEAP (Protected EAP)
For the PEAP method, only the RADIUS server issues a digital certificate. The server certificate sent from the RADIUS server is verified using the CA certificate on the client. The CA certificate used to verify the server certificate must be registered. For information on installing the CA certificate file using the Remote UI, see "Installing a CA Certificate File." For instructions on registering the installed CA certificate file, see "Registering/Editing a CA Certificate File."
Furthermore, the name of the user/login user to be authenticated with IEEE802.1X authentication and the password need to be set to use PEAP with the machine.
The only internal authentication protocol supported by PEAP is MS-CHAPv2.
You cannot set the EAP-TLS method and the EAP-TTLS/PEAP method at the same time.
