Category Top
Optional Equipment and System Requirements
Printing or Sending a Fax from a Computer
Using E-Mail/I-Fax
Sending Data
Checking Your Network Environment
Network Environment Setup Procedures
Connecting the Machine to a Computer or Network
Specifying Network Settings from the Touch Panel Display
Interface Settings
Communication Environment Setup
IEEE802.1X Authentication Settings
Selecting the IEEE802.1X Authentication Method
TCP/IP Network Setup Procedures
Protocol Settings
TCP/IPv4 Settings
TCP/IPv6 Settings
Settings Common to TCP/IPv4 and TCP/IPv6
Confirming TCP/IPv4 Settings (PING Command)
Confirming TCP/IPv6 Settings (PING Command)
Setting the Key Pair Used With SSL Encrypted Communications
IPSec Settings
Registering a Security Policy
Editing a Security Policy
Startup Time Settings
Setting Up a Computer for Printing/Sending a Fax
Printer Connection Method (LPD/Raw)
Windows XP/Server 2003/Server 2008/Vista/7/Server 2008 R2/8/Server 2012
Mac OS X 10.5 - 10.8
UNIX
Printer Connection Method (IPP/IPPS)
Printer Connection Method (FTP)
Printer Connection Method (WSD)
Setting Up a Computer as a File Server
FTP Server Settings
WebDAV Server Settings
NetWare Network Setup Procedures
NetWare Print Service Settings
Setup Using NetWare Administrator or PCONSOLE
Protocol Settings
SMB/CIFS Network Setup Procedures
Protocol Settings
Connecting to a TCP/IP Network
Connecting to an SMB/CIFS Network and Configuring a Shared Folder
Network Connection Problems and Remedies
Printing Problems and Remedies
Data Sending/File Sharing Problems and Remedies
Encrypted SSL Data Communication Problems and Remedies
Confirming Settings
Checking the Block Log
Obtaining the Public Key of the Machine to Use SSL with Windows Server 2008/Vista/7/Server 2008 R2/8/Server 2012
Top » Network » Printing Problems and Remedies
0C1Y-1F1
This section describes how to resolve basic printing problems.
Unable to Install a Driver (TCP/IP Network)
Cause
Communication via the IP address of a computer in which you intend to install a driver is not permitted in [Firewall Settings] on the machine.
Remedy
If you intend to print using TCP/IP, in order to install the printer driver correctly, communication via the IP address of the computer on which you intend to install the driver must be permitted in [Firewall Settings] on the machine. Check whether communication via the IP address of the computer is permitted in [Firewall Settings] on the machine. (See steps 13 to 16 in "TCP/IPv4 Settings," or steps 9 to 11 in "TCP/IPv6 Settings.")
Unable to Print from a TCP/IP Network
Cause 1
The machine and cable are not properly connected.
Remedy
Confirm the following, and turn the main power switch of the machine On.
That the machine is connected to the network using the correct cable. (See "Connecting the Machine to a Computer or Network.")
Cause 2
TCP/IP network is not properly set up.
Remedy
Check the following:
Confirm that the IPv4 addresses are properly set up. If the IPv4 addresses were set using DHCP or Auto IP, confirm that they are operating.
Confirm that the IPv6 addresses are properly set up. After checking the settings of the router, set <Use Stateless Address> to 'On' to confirm whether you can obtain an address. If the IPv6 addresses were set using DHCPv6, confirm that DHCPv6 is operating.
Your computer may not be able to recognize the machine even though the IP address settings are appropriate. This problem may be resolved by delaying the startup of network communications for the machine. (See "Startup Time Settings.")
Cause 3
The computer that is printing is not properly set up. (Windows)
Remedy
Confirm that the proper printer driver is installed. If you are printing from Windows, each computer must have a printer driver installed. (See "Printing from a Computer (Windows),""Sending a Fax from a Computer (Windows).")
Confirm that the correct printer is set as the output destination for the computer that is printing. You can confirm the output destination by following the procedure below to display the printer icon:
Windows XP Professional/Server 2003: From the [Start] menu, select [Printers and Faxes].
Windows XP Home Edition: From the [Start] menu, select [Control Panel] - [Printers and Other Hardware] - [Printers and Faxes].
Windows Vista: From the [Start] menu, select [Control Panel] → double-click [Printers].
Windows Server 2008: From the [Start] menu, select [Control Panel] → double-click [Printer].
Windows 7/Server 2008 R2: From the [Start] menu, select [Control Panel] → [View devices and printers] for [Hardware and Sound].
Windows 8/Server 2012: Place the cursor on the top right (bottom right) of the desktop → select [Settings] → [Control Panel] → [Devices and Printers] for [Hardware and Sound]/[Hardware].
Cause 4
The computer that is printing is not properly set up. (Macintosh)
Remedy
Check the following Macintosh settings:
Confirm that the proper printer has been selected as the destination.
Cause 5
The name of the file being printed is too long.
Remedy
Normally LPR sends jobs either under the name of the application software used for printing or under the file name. However, a job name longer than 255 characters cannot be sent to the printer. To correct this problem, rename the file with a shorter name.
Cause 6
Communication via the IP address of the computer from which data is to be sent to the machine is not permitted in [Firewall Settings] on the machine.
Remedy
Cause 7
An error message appears on the touch panel display of the machine.
Remedy
After confirming the error message, see "List of Error Messages" and perform the necessary operations according to the error message displayed.
Unable to Perform WSD Printing
Cause
WSD printing has not been set.
Remedy
Check whether communication via the IP address of the computer is permitted in [WSD Settings] on the machine. (See step 7 in "Settings Common to TCP/IPv4 and TCP/IPv6.")
Unable to Perform IPP Printing
Cause
IPP printing has not been set.
Remedy
Check whether communication via the IP address of the computer is permitted in [IPP Print Settings] on the machine. (See step 9 in "Settings Common to TCP/IPv4 and TCP/IPv6.")
Unable to Print from a NetWare Network
Cause 1
Remedy
Cause 2
The NetWare network is not properly set up.
Remedy
Confirm that the NetWare file server is running.
Confirm that there is sufficient disk space on the NetWare file server. Large files cannot be printed if there is insufficient disk space.
Start NWADMIN or PCONSOLE, and then confirm that the print queue is set up properly and is active.
Confirm that the network settings of the machine are correctly set. (See "Protocol Settings.") Check the following in particular:
A valid frame type is selected from the <Frame Type> drop-down list.
[Print Server Name] and [Printer Number] are correctly specified.
Cause 3
Remedy
Cause 4
If you are using an NDS PServer or Bindery PServer and the print server has a password setting, the machine's password setting is incorrect.
Remedy
Perform the following steps to correct the machine's password setting: Confirm the password in the NetWare print server for printing on the machine.
Press [Preferences] (Settings/Registration) → [Network] → [NetWare Settings].
Press [Set] → [Print Server Password].
Enter the password → press [OK].
On the Confirm screen, enter the same password to confirm the password → press [OK].
Press [OK] → [OK].
Cause 5
Remedy
