Category Top
Optional Equipment and System Requirements
Printing or Sending a Fax from a Computer
Using E-Mail/I-Fax
Sending Data
Checking Your Network Environment
Network Environment Setup Procedures
Connecting the Machine to a Computer or Network
Specifying Network Settings from the Touch Panel Display
Interface Settings
Communication Environment Setup
IEEE802.1X Authentication Settings
Selecting the IEEE802.1X Authentication Method
TCP/IP Network Setup Procedures
Protocol Settings
TCP/IPv4 Settings
TCP/IPv6 Settings
Settings Common to TCP/IPv4 and TCP/IPv6
Confirming TCP/IPv4 Settings (PING Command)
Confirming TCP/IPv6 Settings (PING Command)
Setting the Key Pair Used With SSL Encrypted Communications
IPSec Settings
Registering a Security Policy
Editing a Security Policy
Startup Time Settings
Setting Up a Computer for Printing/Sending a Fax
Printer Connection Method (LPD/Raw)
Windows XP/Server 2003/Server 2008/Vista/7/Server 2008 R2/8/Server 2012
Mac OS X 10.5 - 10.8
UNIX
Printer Connection Method (IPP/IPPS)
Printer Connection Method (FTP)
Printer Connection Method (WSD)
Setting Up a Computer as a File Server
FTP Server Settings
WebDAV Server Settings
NetWare Network Setup Procedures
NetWare Print Service Settings
Setup Using NetWare Administrator or PCONSOLE
Protocol Settings
SMB/CIFS Network Setup Procedures
Protocol Settings
Connecting to a TCP/IP Network
Connecting to an SMB/CIFS Network and Configuring a Shared Folder
Network Connection Problems and Remedies
Printing Problems and Remedies
Data Sending/File Sharing Problems and Remedies
Encrypted SSL Data Communication Problems and Remedies
Confirming Settings
Checking the Block Log
Obtaining the Public Key of the Machine to Use SSL with Windows Server 2008/Vista/7/Server 2008 R2/8/Server 2012
Top » Network » TCP/IP Network Setup Procedures
0C1Y-1CJ
To use a TCP/IP network, it is necessary to perform the following procedures.
1.Protocol Settings
Specify the protocol settings. To specify the settings, use one of the following:
The machine's control panel
The Remote UI (via a Web browser)
Canon utilities
2.Setting Up a Computer for Printing/Sending a Fax
Specify the settings of each computer you use for printing or sending a fax.
3.Setting Up a Computer as a File Server
Specify the settings of the computer receiving data sent from the machine.
It is recommended that you consult the administrator for the network you are using when performing the settings in steps 1 and 3.
The machine or printing equipment does not come with printer driver software that can be used on a UNIX platform. (Use LPD to set up a printer in UNIX.)
The machine does not come with fax driver software for the UNIX platform, it is not possible to send a fax from a UNIX platform.
Pre-determined ports must be opened in order to initiate network communication using TCP/IP. The required ports can be opened by selecting [On] for the appropriate [Network] settings in the machine. It is recommended that the settings for any unused functions be set to 'Off'. When a port is opened, it is possible for a third person to gain unauthorized access.
