If originals that have been fed through the feeder have streaks or appear dirty, clean the feed rollers.
Clean the rollers of the feeder with a cloth which is wrung after being dampened in water, and then wipe them clean with a soft, dry cloth.
Spin the rollers while cleaning them.
If the document feed scanning area is dirty, documents may not be scanned clearly, and the size of the document may not be detected correctly.
Do not dampen the cloth too much, as excess water may damage the machine.
Gently open the feeder cover.
When the feeder cover is completely opened, the inner cover is also opened.
* Inner Cover
Clean the rollers (a total of eight places) inside the feeder cover with a water-moistened cloth. Then, wipe the area with a soft, dry cloth.
Spin the rollers with your hand while cleaning them.
Clean the rollers (a total of four places) inside the inner cover with a water-moistened cloth. Then, wipe the area with a soft, dry cloth.
4.
Clean the transparent plastic parts of the inner cover and inside it (a total of three places) with a water-moistened cloth. Then, wipe the area with a soft, dry cloth.
5.
Lift the feeder.
6.
Clean the feeder scanning area (the left side of the platen glass) and the white strip of plate under the feeder with a water-moistened cloth. Then, wipe the area with a soft, dry cloth.
* Feeder Scanning Area
7.
Hold the feeder with one hand, and then open the cover under the feeder with the other.
8.
Clean the rollers (a total of eight places) inside the cover under the feeder with a water-moistened cloth. Then, wipe the area with a soft, dry cloth.
9.
Close the cover under the feeder.
 CAUTION
When closing the feeder, be careful not to get your fingers caught, as this may result in personal injury.
10.
Gently lower the feeder.
 CAUTION
When lowering the feeder, be careful not to get your fingers caught, as this may result in personal injury.
11.
Gently close the feeder cover.
 CAUTION
When closing the cover, be careful not to get your fingers caught, as this may result in personal injury.
