Replacing the Toner Cartridge
When the message <Replace toner cartridge.> is displayed on the touch panel display, press on the bottom right and replace the toner cartridge.
When the toners run out completely and prints can no longer be made, a screen with instructions on how to replace the toner cartridge appears on the touch panel display. Follow the procedure described below to replace the toner cartridge.
If you press [Close], you can continue operations, such as setting modes and scanning originals, even if you do not replace the toner cartridge immediately.
WARNING
Do not burn or throw used toner cartridges into open flames, as this may cause the toner to ignite, resulting in burns or a fire.
If you accidentally spill or scatter toner, carefully gather the toner particles together or wipe them up with a soft, damp cloth in a way that prevents inhalation. Never use a vacuum cleaner that does not have safeguards against dust explosions to clean up spilled toner. Doing so may cause a malfunction in the vacuum cleaner, or result in a dust explosion due to static discharge.
CAUTION
Keep toner out of the reach of small children.
If toner is ingested, consult a physician immediately.
If toner gets onto your hands or clothing, wash it off immediately with cold water. Washing it off with warm water will set the toner, and make it impossible to remove the toner stains.
Use only toner cartridges intended for use with this machine.
For information on the supported Canon genuine toner, see "Consumables."
Do not replace toner cartridges until the message prompting you to do so appears.
Do not attempt to replace the toner cartridge while the machine is printing.
Complete instructions on how to replace the toner cartridge can be accessed by pressing [Previous] or [Next] on the touch panel display.
If toner runs out during a print job, the remaining prints are made after you replace the toner cartridge.
Press .
If a screen with instructions on how to replace the toner cartridge appears on the touch panel display, this step is not necessary.
Open the front cover.
1. Lift the control panel.
2. Open the front cover.
Remove the displayed toner cartridge.
* Toner Cartridge Lock Lever
1.Turn the toner cartridge lock lever counterclockwise so that the arrow marks on the lever and its axis face each other.
2. Pull the toner cartridge out of the toner supply port.
Pull the toner cartridge out halfway with one hand, support it with the other hand from underneath, and then remove it completely while keeping it level.
WARNING
Do not burn or throw used toner cartridge into open flames, as this may cause the toner remaining inside the cartridges to ignite resulting in burns or a fire.
If the toner cartridge cannot be pulled out, check that the lever is turned all the way to the appropriate position.
4.
Prepare the new toner cartridge.
1. Open a package and remove the toner cartridge.
2. Remove the protective cap from the new toner cartridge.
Twist the protective cap of the new toner cartridge in the direction of the arrow to remove it.
Use only toner cartridges intended for use with the machine. (See "Consumables.")
Do not touch the opening of the toner cartridge or subject it to shock by hitting it. Doing so may cause the toner to leak out of the cartridge.
5.
Insert the new toner cartridge in the toner supply port as far as it will go.
Support the new toner cartridge with your hand from underneath while pushing it into the machine with your other hand.
6.
Turn the toner cartridge lock lever clockwise so that the arrow marks on the lever and its axis face each other.
7.
Close the front cover.
1. Close the front cover of the main unit.
2. Lower the control panel back in place.
CAUTION
When closing the covers, be careful not to get your fingers caught, as this may result in personal injury.
» Maintenance » Replacing the Toner Cartridge
0C1Y-0EW
