Adjusting a Paper Drawer to Hold a Different Paper Size
If you want to load a different size paper into a paper drawer, follow the procedure described below to adjust the paper drawer guides.
 CAUTION
When handling paper, take care not to cut your hands on the edges of the paper.
Remove the paper loaded in the paper drawer.
1. Press and release the button on the paper drawer in which you want to adjust.
2. Grip the handle, and pull out the paper drawer until it stops.
3. Remove all of the remaining paper.
Adjust the position of the Side Guide.
1. Squeeze the lever on the side guide.
2. Without releasing the lever, slide the side guide leftward or rightward to align it with the mark for the desired paper size.
*1: Lever
*2: Side Guide
Adjust the position of the Front Guide.
1. Squeeze the lever on the front guide.
2. Without releasing the lever, slide the front guide backward or forward to align it with the mark for the desired paper size.
*1: Lever
*2: Front Guide
Adjust the guides correctly. Failure to do so may cause paper jams or dirty prints, or make the inside of the machine dirty.
4.
Load the appropriate size paper into the paper drawer.
1. Make sure that the paper size setting of the paper drawer matches the size of the paper to load in the paper drawer.
2. Load the paper stack against the right wall of the paper drawer.
3. Gently push the paper drawer back into the machine until it clicks into place in the closed position.
 CAUTION
When returning the paper drawer to its original position, be careful not to get your fingers caught, as this may result in personal injury.
5.
Place the appropriate paper size label on the paper drawer.
The paper sizes marked on the labels may include sizes that the machine is unable to use.
6.
Specify the paper type as required.
Make sure that the paper type setting of the paper drawer matches the type of the paper that is being loaded.
