The imageRUNNER ADVANCE features numerous functions enabling you to perform such convenient operations as scanning paper documents, outputting data, and sending/receiving faxes.
The imageRUNNER ADVANCE is designed to meet your needs whilst streamlining workflow, greatly enhancing the productivity of your business.
The imageRUNNER ADVANCE incorporates a user-friendly touch display panel that can be customized to suit the needs of the individual or office environment. This practical feature enables users to customize the layout of the display, as well as register frequently performed operations on the Quick Menu, ensuring that every user experiences remarkable efficiency.
In today's highly-competitive global market, cost savings are more crucial than ever. The total cost of ownership (TCO) must be taken into consideration when a business invests in office equipment. A positive bottom line and improved efficiency can be achieved by reducing the cost and workload involved in transmitting information. Operating a network of imageRUNNER ADVANCE systems enables you to share address books for uniform management, and even share the fax function of another imageRUNNER ADVANCE machine using the Remote Fax function.
Robust security is vital to all businesses.
The imageRUNNER ADVANCE incorporates a secure watermark function to restrict the misuse of output documents. In addition to this, security solutions are offered for various operations, such as printing and transmitting data.
To use the various functions described in this manual, depending on the function, you may need to specify certain settings in advance using one of the following three methods:
This method enables you to specify the settings required to perform network-related operations such as using Internet fax (I-fax) and e-mail, configuring fax forwarding settings, and accessing the Advanced Boxes of other imageRUNNER ADVANCE machines. You can also set security-related functions by browsing through the directory levels which are grouped by purpose.
The items available in Settings/Registration vary for the administrator and general user.
The system manager or the SSO-H (Single Sign-On H) Administrator can specify all of the system settings for the machine. For information on the types of administrators, see
"Administrator Settings."
System Manager Information (System Manager Department ID/System PIN) is set by default in the machine. Thus, the Administrator must log in by entering the System Manager ID and the System PIN on the Settings/Registration screen. The default settings for the system manager department ID and system manager PIN are both "7654321." These should be changed to more suitable values.
Items Requiring Prior Confirmation
Check the following items when specifying settings:
Item
Sample Setting
Setting Method
IPv4 Address of the Machine
172.24.156.11
Press ![](./images/book_images/b_in_Add_S.gif) (Settings/Registration) → [Preferences] → [Network] → [TCP/IP Settings] → [IPv4 Settings] → [IP Address Settings].
Subnet Mask of the Machine
255.255.255.0
Gateway Address of the Machine
172.168.1.254
Primary Server of the Machine
10.120.5.11
Press ![](./images/book_images/b_in_Add_S.gif) (Settings/Registration) → [Preferences] → [Network] → [TCP/IP Settings] → [DNS Settings] → [DNS Server Address Settings].
Secondary Server of the Machine
10.120.10.55
Host Name
imageRUNNER ADVANCE
Press ![](./images/book_images/b_in_Add_S.gif) (Settings/Registration) → [Preferences] → [Network] → [TCP/IP Settings] → [DNS Settings] → [DNS Host/Domain Name Settings].
Domain Name
Smc.co.jp
E-mail Address of the Machine
iRADV@smc.co.jp
Press ![](./images/book_images/b_in_Add_S.gif) (Settings/Registration) → [Function Settings] → [Send] → [E-Mail/I-Fax Settings] → [Communication Settings].
SMTP Server
SMTPSV.smc.co.jp
POP Server
POPSV.smc.co.jp
POP Login Name
Air
POP Password
ACC123
Using your computer, you can install the printer driver, as well as specify various print settings. The printer driver can be installed using the CD-ROM accompanying the machine, or via the Internet. You can also create shared folders to store and share scanned documents.
Using the Web browser installed in the computer you are using, you can perform various operations including specifying settings, restarting the machine, and switching the authentication method.
Remote UI:
Configure [Settings/Registration] from your desk.
Conditions
Network settings are set.
Press
(Settings/Registration) → [Preferences] → [Network] → [TCP/IP Settings] → set [Use HTTP] to 'On'.
Press
(Settings/Registration) → [Management Settings] → [License/Other] → set [Remote UI] to 'On'.
System Requirements
Windows
Compatible OS
Compatible Web Browsers
Windows XP Windows Vista Windows 7
Internet Explorer 6, or later
Macintosh
Compatible OS
Mac OS X v10.3, or later
Safari 1.3.2, or later
SMS (Service Management Service):
Switch the authentication method for your machine.
Conditions
Press
(Settings/Registration) → [Preferences] → [Network] → [TCP/IP Settings] → [Use HTTP] to 'On'.
A key pair and server certificate preinstalled in the machine are set as the default key.
Press
(Settings/Registration) → [Preferences] → [Network] → [TCP/IP Settings] → [SSL Settings] → select [Default Key] (the preinstalled key pair and server certificate) in [Key and Certificate] → press [Set as the Default Key].
System Requirements
Windows
Compatible OS
Windows XP Professional SP3
Internet Explorer 7 Internet Explorer 8
Windows Vista SP2
Internet Explorer 7 Internet Explorer 8 Internet Explorer 9
Windows 7 SP1
Macintosh
Compatible OS
Mac OS X v10.5
Safari 4.0.5
Safari 5.0.5
Mac OS X v10.6
Safari 4.0.5 Safari 5.0.5 Safari 5.1
Mac OS X Lion
Safari 5.1
User Access Control for Advanced Box:
A login service that manages the user information for Advanced Box users.
