Enabling PDF Documents to Be Edited with Adobe Reader (Reader Extensions)
If you select the Reader Extensions mode when converting a paper document to a PDF file, you can add/edit comments, and add signatures using Adobe Reader (Adobe Reader 7 or later).
Benefits of Reader Extensions
Utilize PDF Files at a Low Cost
To add signatures or edit a PDF file, it is necessary to install PDF editing software such as Adobe Acrobat in your computer. However, you can reduce adoption costs by using the Reader Extensions mode to add signatures and make edits, even if the above software is not installed in your computer.
Fast Decision Making with Document Sharing
For example, when a project member is collecting comments on a preliminary plan, they can convert the draft document to a PDF file and save it in a shared folder that the members can access. Comments can then be collected in a faster manner than if a paper document was being passed around.
Required Condition
The Universal Send Advanced Feature Set is activated.
Network settings are set.
This section describes the procedure for saving a paper document in the shared folder of the Advanced Box in the Reader Extensions format. Multiple people will be allowed to view and edit the PDF file.
The screens may differ, depending on the model of the machine and on attached optional products.
Follow the procedures below.
Checking Whether the Advanced Box Can Be Accessed
Checking Whether Documents Can Be Saved in the Reader Extensions Format
Converting the Document to a PDF File in the Reader Extensions Format
Opening the Saved Document with Adobe Reader
It is necessary to check whether the destination Advanced Box can be accessed from your computer.
Follow the procedure below to check that the Advanced Box can be accessed with SMB.
Press (Settings/Registration) → [Function Settings] → [Store/Access Files] → [Advanced Box Settings] → [Open to Public] → [By SMB] → [OK].
Follow the procedures below to check whether [Prohibit Writing from External] is set to 'Off'.
Press (Settings/Registration)→ [Function Settings] → [Store/Access Files] → [Advanced Box Settings] → [Prohibit Writing from External].
Check that any functions that are incompatible with the Reader Extensions format are disabled.
Follow the procedure below to confirm that [Format PDF to PDF/A] is set to 'Off'.
Press (Settings/Registration) → [Function Settings] → [Common] → [Generate File] → [Format PDF to PDF/A].
Select [Off] → press [OK].
In addition to this setting, you cannot save in the Reader Extensions format if (Settings/Registration) → [Function Settings] → [Common] → [Generate File] → [Optimize PDF for Web] is set to 'On' and a digital signature is set.
Scan a paper document and convert it to a PDF file.
Press [Scan and Store] on the Main Menu screen.
Press [Advanced Box].
If the Log In screen is displayed, enter the user name and password → press [OK].
Enter the same user name and password used to log in to the machine.
After you are finished using the machine, press (Log In/Out) to log out.
If you are using SSO-H as the login service, press [Store Password] to store your user name and password. Next time you log in to the Advanced Box, the user name and password will already be entered and you can display the Space Selection screen by simply pressing [OK]. If the Log In screen is not displayed, this step is not necessary.
4.
Press [Shared Space].
5.
Select the folder to store the file in.
6.
Place your originals.
7.
Press [Scan].
8.
Press [File Format].
9.
Select [PDF] → [Reader Extensions] → [OK].
10.
Press (Start).
If the following screen is displayed, follow the instructions on the touch panel display → press (Start) once for each original. When scanning is complete, press [Start Storing].
When scanning is complete, the scanned data is stored in the selected folder.
You cannot change settings, such as the document size or the scanning ratio, while the machine is scanning.
If you want to cancel scanning, press [Cancel] or (Stop).
11.
When scanning is complete, remove your originals.
Open the PDF document saved in the shared folder of the Advanced Box from your computer.
This section uses Windows 7 as an example.
Click [Start] → [Programs] → [Accessories] → [Windows Explorer] → enter the following path in <Address>. (case sensitive)
\\<IP address of this machine>\share
If the Log In screen is displayed, enter the user name and password → click [OK].
If you successfully log in, you can access the shared space in the Advanced Box.
Select and open the stored PDF file.
4.
Save the PDF document after making an edit such as adding an annotation.
To add a comment, select the icon in the toolbar → click the location in the PDF document to add the comment. You can enter instructions etc. in the displayed entry field.
If an error occurs, check that the time on the machine and the time on the computer match. If you open a Reader Extensions compatible PDF in Adobe Reader, and the time at which the PDF file was created is later than the current time on the computer, an error occurs.
Reference Information
"PDF/A-1b" Format for Meeting ISO Standards
PDF/A is a standard set by the International Organization for Standardization (ISO). It is suited for long-term storage because it guarantees that the display of the PDF does not change with the machine or viewing software.
To save a PDF file in the PDF/A-1b format, press (Settings/Registration) → [Function Settings] → [Common] → [Generate File] → set [Format PDF to PDF/A] to 'On' → convert the document to a PDF file using [Scan and Store] or [Scan and Send].
Optimizing PDF Files for Web Viewing
When viewing PDF files on the Web, you can optimize the files so that they can be viewed as each page is downloaded, without having to wait for the entire document to download. This is useful when distributing scanned data via the Web.
To save a PDF file optimized for the Web, press (Settings/Registration) → [Function Settings] → [Common] → [Generate File] → set [Optimize PDF for Web] to 'On' → convert the document to a PDF file using [Scan and Store] or [Scan and Send].
Cautions when Generating PDF Files
There are several combinations of settings that cannot be used when converting a paper document to a PDF file.
Unavailable Setting Combinations
Description
Remedy
Reader Extensions and PDF/A
If [Format PDF to PDF/A] in Settings/Registration is set to 'On', you cannot select the Reader Extensions format.
Set [Format PDF to PDF/A] to 'Off'.
Reader Extensions and Encrypted PDF
If password authorization is set for Encrypted PDF, you cannot set the Reader Extensions format.
Allow [Signature Field Signing], [Commenting and Signature Field Signing], [Changes but Add Comments/Extract Pages], or [Changes but Extract Pages] for Encrypted PDF.
PDF/A and Encrypted PDF
If [Format PDF to PDF/A] in Settings/Registration is set to 'On', you cannot select Encrypted PDF.
Encrypted PDF and Digital Signature (Device Signature and User Signature)
If password authorization is set for Encrypted PDF, you cannot set a digital signature.
Allow [Changes but Extract Pages] for Encrypted PDF.
» Practical Workflows » Digitizing Paper Documents » Enabling PDF Documents to Be Edited with Adobe Reader (Reader Extensions)
08KY-23E
