      0SU0-014
      Entering Sleep Mode
      The sleep mode function reduces the amount of power consumption by temporarily disabling some internal operations of the machine. If no operations will be performed on the machine for a while, such as during a lunch break, you can save power simply by pressing  on the operation panel. You can also use the <Auto Sleep Time> setting to automatically put the machine into sleep mode if it remains idle for a specified period of time.
      When in sleep mode
      When the machine enters sleep mode,  lights up yellow green.
      Situations in which the machine does not enter sleep mode
      When the machine is in operation
      When the [Processing/Data] indicator is lit up or blinking
      When the machine is performing an operation such as adjustment or cleaning
      When a paper jam occurs
      When the setting menu screen is displayed
      When an error message is displayed on the screen (There are some exceptions. The machine sometimes enters sleep mode when error messages are displayed.)
      When the machine is communicating with a server.
      When You Want to Set the Auto Sleep Timer
      The factory default setting for the amount of time that elapses before the machine enters auto sleep mode is 5 minutes (setting range is 3 to 240 minutes). It is recommended to use the factory-installed settings for this item. If you want to change the amount of time that elapses before the machine enters auto sleep mode, follow the procedure below.
        <Timer Settings>    <Auto Sleep Time>    Set the amount of time that elapses before the machine automatically enters sleep mode
      Exiting Sleep Mode
      Press  or any other key to exit sleep mode.
      Pressing a key on the connected USB keyboard (Entering Characters Using a USB Keyboard) may exit sleep mode.
