      0SU0-013
      Specifying the Sound Settings
      The machine produces sounds in a variety of situations, such as when a key is pressed or when a paper jam or error occurs. Specify the sound settings by following the procedure below.
      1
      Press .
      2
      Use / to select <Preferences>, and press .
      3
      Select <Sound Volume Control>, and press .
      4
      Select a setting, and press .
      Setting
      Description
      Procedure
      <Entry Tone>
      Sound produced each time a key on the operation panel is pressed
      <On> (Sound is produced) or <Off> (No sound is produced)    Go to step 5
      <Invalid Entry Tone>
      Sound produced when an invalid key operation is performed, such as when you enter a number outside the valid setting range
      <Restock Supplies Tone>
      Sound produced when the toner cartridge is almost empty
      <Warning Tone>
      Sound produced when a paper jam or other error occurs
      <Job Done Tone>
      Sound produced when an operation such as printing is complete
      <Energy Saver Alert>
      Sound produced when the machine enters or exits sleep mode
      5
      Press  to close the menu screen.
