Changing Default USB Print Settings
The default settings are the settings that are displayed whenever you turn ON the machine, or when you press
. If you change these default settings to match the operations that you perform frequently, you can eliminate the need to specify the same settings every time you make prints.
Settings
Select the item you want to set, and change the default value.
LINKS
