All the settings about the memory media print are listed with short descriptions. Default settings are marked with a dagger (
Asterisks (*)
Settings marked with "*1" are only available when the optional paper drawer (drawer 2) is attached.
Settings marked with "*2" are only available for the imageRUNNER 1435iF, or the imageRUNNER 1435i / 1435 with the optional USB Direct Print Kit (for PDF) or PS Printer Kit enabled.
To print PDF files on the imageRUNNER 1435i / 1435
You need the optional USB Direct Print Kit (for PDF) or PS Printer Kit.
1
to 99 |
Multi-Purpose Tray
Drawer 1
![]() Drawer 2*1
Off
![]() 2 on 1
4 on 1
Off
![]() Book Type
Calendar Type
Off
![]() On
Off
![]() On
Photo Priority
![]() Text Priority
Five Levels
Gradation
Error Diffusion
Off
![]() On
Off
![]() On
Off
![]() Auto
Halftones
Text
Gradation
Resolution
![]() High Resolution
Graphics
Gradation
Resolution
Gradation
Resolution
Grayscale Conversion
sRGB
NTSC
![]() Uniform RGB
Print Quality
Density
Density: 17 Levels
Density (Fine Adjust)
High: 17 Levels
Medium: 17 Levels
Low: 17 Levels
Toner Save
Off
![]() On
Image Refinement
Off
On
Name (Ascending)
![]() Name (Descending)
Date/Time (Ascending)
Date/Time (Descending)
<Memory Media Print Settings>
<File Sort Default Settings>
Select the order of files that are displayed
Short File Name
Long File Name ![]() |
<File Name Display Format>
Select <Short File Name> or <Long File Name>
<Short File Name>
<Long File Name>
<Initialize Default Settings>
<Yes>
