* Only available for the imageRUNNER 1435iF, or the imageRUNNER 1435i / 1435 with the optional USB Direct Print Kit (for PDF) or PS Printer Kit enabled.
For JPEG and TIFF files, maximum printable data size per file*1 is 50 MB*2.
*1 For multi-page TIFF files, maximum data size is per page.
*2 Maximum data size is 20 MB when Secure Print is enabled.
For PDF files, maximum printable data size per file is 2 GB.
Note that even some files smaller than the size described above may not be printed correctly.
Do not use non-standard USB memory devices. You may not be able to print the files properly with some USB memory devices.
Do not connect anything other than a USB memory device. USB memory devices cannot be connected via a USB hub or an extension cable.
Do not use USB memory devices with special functions such as built-in security functions.
If a folder in a USB memory device has many files, scanning files to print will take more time. Use your computer to delete unnecessary files on your USB memory device or move them to a different folder.
(DIRECT PRINT).
to select <Select File and Print>, and press
To change the file sort order
1
Select <Sort Files>, and press
2
Select the criteria for file sorting, and press
NOTE:
When you select <Date/Time (Ascending)> or <Date/Time (Descending)>, files are sorted based on the modification dates and time of the files.
), and press
. To return to the folder in the upper level, press
(Back) or
To select all files
. All the displayed files are selected.
To specify the print settings for all file formats
to select the settings, press
and specify each setting.
or the numeric keys to enter a quantity, and press
to select the paper, and press
to select <2 on 1> or <4 on 1>, and press
<2 on 1>
<4 on 1>
to select the binding position, and press
<Book Type>
<Calendar Type>
NOTE:
<2-Sided> may not be available with some sizes or types of paper. Paper
You can specify the 2-sided setting by pressing
(2-Sided), instead of selecting <2-Sided> as the procedure described above. |
To specify the print settings only for JPEG/TIFF files
to select <Set JPEG/TIFF Details>
specify the setting
<Apply>
to select <On>, and press
to select <Photo Priority> or <Text Priority>, and press
<Text Priority>
<Photo Priority>
to adjust the brightness, and press
to select <Gradation> or <Error Diffusion>, and press
<Gradation>
<Error Diffusion>
To specify the print settings only for PDF files
to select <Set PDF Details>
specify the setting
<Apply>
to select <Auto>, and press
specify the setting
<Apply>
<Halftones>
<Grayscale Conversion>
<Print Quality>
<Yes>
1
Press
2
Press
(Status Monitor). |
3
Use
/ to select <Device Status>, and press . |
4
Select <Remove Memory Media>, and press
.Wait until the <Memory media can be safely removed.> message is displayed.
5
Disconnect the USB memory device.
TIPS
If you always want to print with the same settings: Changing Default USB Print Settings
