0KCF-053
Combining and Printing Multiple Documents
By using Canon PageComposer, you can combine multiple documents into one print job and print the job with specified print settings. This function, for example, enables you to combine documents made with different applications and print all of the pages in the same paper size.
1
Open a document in an application and display the print dialog box.
How to display the print dialog box differs for each application. For more information, see the instruction manual for the application you are using.
2
Select the printer driver for the machine, and click [Preferences] (or [Properties]).
3
Select [Edit and Preview] in [Output Method].
Click [OK] on the [Information] pop-up screen.
Click [OK] at the bottom of the screen.
4
Click [Print] (or [OK]).
The Canon PageComposer starts. Printing does not start in this step.
5
Repeat steps 1 to 4 for the documents you want to combine.
The documents are added to the Canon PageComposer.
6
From the [Document Name] list, select the documents to combine, and click .
To select multiple documents, click the documents while holding down [SHIFT] key or [CTRL] key.
7
Change the settings as necessary, and click [Combine].
The documents selected in step 6 are combined.
 [Print Preview]
Displays a preview of the document to be printed.
 [Document List]/[Print Settings]
Click the [Document List] tab to display the documents added in steps 1 to 4. You can remove documents by selecting them in the list and clicking [Delete from List].
Click the [Print Settings] tab to display the screen for specifying print settings such as the number of copies or 1-sided/2-sided printing. The settings specified here are applied to the whole print job.
NOTE:
For more information, click [Help] on the Canon PageComposer screen.
 [Details]
Displays the print setting screen of the printer driver. There are fewer settings available than when using the ordinary printing method.
8
On the [Document Name] list, select the combined-document print job you want to print, and click .
Printing starts.
For instructions on how to cancel printing, see Canceling Prints.
