You can print watermarks such as "COPY" or "CONFIDENTIAL" over the document. You can create new watermarks or use pre-registered watermarks.
[Page Setup] tab
Select the [Watermark] check box
Select a watermark from [Watermark Name]
[OK]
[Watermark]/[Watermark Name]
Select the [Watermark] check box to display the list of the watermarks in the [Watermark Name] drop-down list. Select a watermark from the menu.
[Edit Watermark]
Displays the screen to create or edit watermarks.
[Add]
Click to create a new watermark. Up to 50 watermarks can be registered.
[Name]
Enter the created watermark name.
[Attributes]/[Alignment]/[Print Style]
Click each tab to specify the text or print position of the watermark. For more information, click [Help] on the printer driver screen.
LINKS
