Useful in the Following Cases
When your documents are not printed for a long time, you may want to see the waiting list of the documents waiting to be printed.
When you cannot find your printouts that you thought had been printed, you may want to see whether an error has occurred.
1
Select <Job Status>, and press
2
Select the document whose status you want to check, and press
![]() ![]() ![]() Displays a list of the documents that are being processed, being copied, or are waiting to be processed.
![]() Displays detailed information about the document selected from the list.
1
Select <Print Job Log>, and press
2
Select the document whose log you want to check, and press
![]() ![]() ![]() Displays a list of the documents that were printed. <OK> is displayed when a document was printed successfully, and <Error> is displayed when a document failed to be printed because it was canceled or there was some error.
![]() Displays detailed information about the document selected from the list. The displayed document name or user name may not reflect the actual document or user name.
NOTE:
If the <Result> column shows a three-digit number This number represents an error code. When an Error Code Appears
