. (Press to delete each character one by one. Press and hold to delete all the input characters at once.)
To send overseas
1
Enter the international access code.
2
Press
(Pause).<p> (pause) is inserted between numbers. In this case, 012 will be dialed first, then 2 seconds later, the next number will be dialed.
NOTE:
Inputting pauses is optional. However, consecutive numbers that are input without pauses may not be recognized correctly.
Pauses can be inserted continuously.
One pause inserts 2 seconds of waiting time. This time can be changed as necessary. Set Pause Time
3
Enter the country code, the area code, and the fax number.
4
Press
(Pause) to insert a pause at the end of the fax number as necessary, and press .The waiting time inserted here is fixed to 10 seconds. This time cannot be changed.
to start sending.
<Yes>
When placing documents in the feeder in step 1
When placing documents on the platen glass in step 1
1
Use
/ to select the document size, and press .When there is only one page to be scanned, proceed to step 3.
2
Place the next document on the platen glass, and press
.Repeat this step until you finish scanning all of the pages.
3
Select <Start Sending> and press
.The fax is sent.
TIPS
If you always want to send faxes with the same settings:
If you want to register frequently used setting combinations:
If you want to sound an alarm when the handset is off the hook:
