All the settings about the fax are listed with short descriptions. Default settings are marked with a dagger (
Asterisks (*)
Settings marked with an asterisk (*) cannot be exported or imported.
Pulse
Tone ![]() |
Four Levels (Setting to the lowest level turns the sound off)
<Fax Settings>
<Basic Settings>
<Off-Hook Alarm>
Select the volume of the alert sound
Resolution
200 x 100 dpi (Normal)
![]() 200 x 200 dpi (Fine)
200 x 200 dpi (Photo)
200 x 400 dpi (Superfine)
400 x 400 dpi (Ultrafine)
Density
Nine Levels
2-Sided Original
Off
![]() Book Type
Calendar Type
Sharpness
Seven Levels
Off
On
ECM must be enabled on both the machine and the other fax device because error checks are performed on both the sending and receiving devices.
Even when ECM is enabled, errors may occur due to telephone line conditions.
It may take a longer time than usual to process data when ECM is enabled because the error checks and corrections are performed while the data is transmitted.
<Fax Settings>
<TX Function Settings>
<ECM TX>
<On>
1 to 2
to 15 (sec.) |
<Fax Settings>
<Set Pause Time>
Specify the duration of pause
<Apply>
Off
On
![]() Redial Times
1 to 2
to 10 (times)Redial Interval
2
to 99 (min.)Redial When Error Occurs
Off
On
<Fax Settings>
<Auto Redial>
<On>
Specify the settings
<Apply>
<Redial Times>
or the numeric keys to enter a number, and press
<Redial Interval>
or the numeric keys to enter a number for the interval, and press
<Redial When Error Occurs>
to select <Off> or <On>, and press
Off
On
![]() Print Position
Inside Image Area
Outside Image Area ![]() Mark Number as
FAX
![]() TEL |
<Fax Settings>
<TX Terminal ID>
<On>
<Apply>
<Print Position>
<Mark Number as>|
Off
![]() On
<Fax Settings>
<Check Dial Tone Before Sending>
<On>
<Fax Settings>
<Initialize Default Settings>
<Yes>
Off
On
ECM must be enabled on both the machine and the other fax device because error check is performed on both the sending and receiving devices.
It may take a longer time than usual to process data when ECM is enabled because the error check and corrections are performed while the data is transmitted.
<Fax Settings>
<RX Function Settings>
<ECM RX>
<On>
Off
On
![]() 1 to 2
to 99 (times) |
If you use this function in the <Auto> mode, you need to connect your telephone to the machine beforehand.
<Fax Settings>
<Incoming Ring>
<On>
Specify how many times the incoming call rings
Off
On
![]() 00 to 25
to 99 |
<Fax Settings>
<Remote RX>
<On>
Specify the ID number for receiving a fax
Off
![]() On
1 to 15
to 99 (sec.) |
<Fax Settings>
<Switch to Auto RX>
<On>
Specify how long the incoming call rings
Off
![]() On
<Fax Settings>
<RX Print Settings>
<Print on Both Sides>
<On>
Off
On
![]() Ratio
Auto
![]() 97% 95% 90% 75% Direction
Vertical/Horizontal
Vertical Only ![]() |
<Fax Settings>
<RX Print Settings>
<Reduce RX Size>
<On>
<Apply>
<Ratio>
<Direction>|
Off
![]() On |
<Fax Settings>
<RX Print Settings>
<RX Page Footer>
<On>
