      0KCF-03C
      Changing Default Fax Settings
      Change the default settings to match the operations that you perform frequently.
        <Fax Settings>    <TX Function Settings>    <Change Default Settings>    Select the setting    Change the default value of the selected item  <Apply>
      Settings
      Select the item you want to set, and change the default value.
