If you want to cancel sending faxes immediately after pressing
, press
on the operation panel. You can also cancel sending faxes after checking the fax status.
Press
to cancel
If the screen displays a list of documents when
is pressed
Documents have been scanned and are waiting to be processed. Use
to select the document to cancel.
Use
(Status Monitor) to cancel
<Cancel>
Cancels sending.
Fax details
The number of sending document, settings, and other details are displayed. If you only want to check the details without canceling, press
(Status Monitor) to return to the fax main screen.
LINKS
