Registering Frequently Used Fax Settings
You can register up to 18 frequently used combinations of fax settings with desired destinations. You can recall the registered setting combination when it is needed.
1
Press
![](./images/book_images/pubnumbers/USRM2-4883-03/b_key_fax18.gif)
2
Specify the destinations to register.
3
Use
![](./images/book_images/pubnumbers/USRM2-4883-03/b_key_up18.gif)
![](./images/book_images/pubnumbers/USRM2-4883-03/b_key_down18.gif)
to select <Favorite Settings>, and press
![](./images/book_images/pubnumbers/USRM2-4883-03/b_key_ok18.gif)
4
Select <Register/Delete>, and press
Confirm the message on the display, select <OK>, and press
5
Select from <Settings 1> to <Settings 18>, and press
6
Specify the fax settings and change the setting name as necessary.
To change the setting name, select <Change Name>
![](./images/book_images/b_key_arrow_right.gif)
enter the name
<Apply>
7
Select <Apply>, and press
8
Select <Yes>, and press
Registered settings are saved even when the machine is turned OFF.
Using a Registered Setting
LINKS
