      0KCF-017
      Logging on to the Machine
      When Department ID Management is enabled, you must log on before you can use the machine. When the logon screen is displayed, follow the procedure below to enter the Department ID and PIN. The logon process may also be required for the System Manager ID. This section also describes the logon procedure that may be required when you use the fax and scan functions (Logging on to Authorized Send (imageRUNNER 1435iF / 1435i Only)).
      If the screen is displayed prompting you to insert a control card, see Copy Card Reader-F1.
      1
      Enter your Department ID or the System Manager ID.
      1
      Use / to select <Dept. ID> (or <Manager ID>), and press .
      2
      Enter a number of up to seven digits using the numeric keys, and press .
      If no PIN is registered, proceed to step 3.
      2
      Enter the PIN.
      1
      Select <PIN>, and press .
      2
      3
      Press .
      The logon screen switches to the main screen.
      4
      When your operations are complete, press  to log out.
      When you press or , and if the logon screen below is displayed, you must authenticate yourself before using the fax or scan function.
      This logon screen is displayed when Authorized Send, a security feature for sending documents, is enabled.
      1
      Enter your user name.
      1
      Use / to select <User Name>, and press .
      2
      Enter your user name using the numeric keys, select <Apply>, and press .
      You can enter up to 64 alphanumeric characters for the user name. The maximum number of characters you can enter varies depending on the type of entered characters.
      2
      Enter the password.
      1
      Select <Password>, and press .
      2
      Enter the password using the numeric keys, select <Apply>, and press .
      You can enter up to 24 alphanumeric characters for the password.
      3
      Select the server for your authentication.
      1
      Select <Server Name>, and press .
      2
      Select the server, and press .
      Select the LDAP server where your user name and password are registered. If you are not sure, ask your Network Administrator.
      4
      Press .
      The logon screen switches to the fax or scan main screen.
      5
      If the logout confirmation screen is displayed
      If you press a function selection key such as  to switch to another function from the one you are currently using, the logout confirmation screen below is displayed. To log out of Authorized Send (fax or scan function), use / to select <Yes>, and press .
