About the menu options in the following chart
Default settings are highlighted in bold.
The settings marked with "*A" cannot be imported or exported via the Remote UI.
Settings
Descriptions
Change Defaults
You can register scan settings for documents.
E-Mail
You can register scan settings for sending in e-mails and e-mail settings.
Windows (SMB)
You can register scan settings for sending to file servers.
Register Unit Name (E-Mail)
Registering the e-mail sender name.
Settings
Descriptions
Change Defaults
Settings
Descriptions
Color Send Gamma Value
When sending scanned images you can specify the gamma value when the images that were scanned in RGB are converted to YCbCr. When sending the images, optimal image quality can be displayed by setting a gamma value that matches the receiving side.
PDF (Compact) Image Level
Set the PDF (Compact) image level.
