      0WR6-078
      Basic Operations for Scanning Documents
      This section describes the basic operations for scanning documents.
      1
      Place the document. Placing Documents
      2
      Press <Scan and Send> on the Main Menu. <Main Menu> Screen
      3
      Specify the destination on the Scan Basic Features screen. Scan Basic Features Screen
      Specifying Destinations from the Address Book
      Specifying Destinations from One-Touch Buttons
      Entering Destinations Manually
      Specifying Destinations in the LDAP Server
      Specifying Your Own E-Mail Address
      Specifying Personal Folder
      NOTE:
      To specify e-mail destinations as Cc or Bcc, press <Cc Bcc>  <Cc> or <Bcc> <Specify Destinations> before specifying destinations.
      To specify multiple destinations, press <Specify Destinations> and specify an additional destination.
      To delete a destination, select the destination you want to delete, and press <Delete Dest.>.
      4
      Specify the scan settings as necessary.
      Selecting a File Format
      Selecting Resolution
      Specifying the Scanning Size of Documents
      Selecting Color Scan/Black & White Scan
      Scanning Both Sides of Documents
      Enlarging or Reducing
      5
      Press .
      Documents are scanned and sending/saving starts.
      To cancel scanning, press <Cancel> or   <Yes>.
      When <Press the [Start] key to scan the next original.> is displayed
      To cancel sending/saving, press <To Status Mntr./Cncl.>  select a document  <Cancel>  <Yes>.
      Depending on the communication settings, you may be prompted to enter the user name and password. Setting E-mail/I-Fax Communication
      To check the statuses for sent/saved documents
      On the <Status Monitor/Cancel> screen, you can check the statuses for sent/saved documents. This screen enables you to send/save documents again or cancel sending/saving after checking the statuses. Checking Status and Log for Scanned Documents
      To print the report for the results of sending/saving
      On the Scan Basic Features screen, pressing <Options> <TX Report> enables you to set to automatically print the report listing the results of sending/saving.
      File name
      When a file is sent/saved, its file name is automatically set based on the following format. You can change the setting so that a different name can be assigned. Setting a File Name
      When sending by e-mail
      "Job numbers (four digits)_page numbers (three digits).file extension name" format, such as "1042_001.jpg"
      When saving in a file server
      "The year, month, day, hour, minute, and second the file is saved (14 digits).file extension name" format, such as "20151030133541.jpg"
      E-mail subject
      The subject entered in <Default Subject> is automatically set (<E-Mail/I-Fax Settings> <Default Subject>). If you specify a different subject, change the setting, or specify each time you send an e-mail (Specifying E-Mail Settings).
      When multiple sheets are fed
      Scanning is stopped and the message is displayed on the screen. Follow the message and start operation. To set to not notify with a message, press <Options> on the Scan Basic Features screen <Detect Feeder Multi Sheet Fd.> each time you send/save a document to disable the setting, or set <Set Detection of Feeder Multi. Sheet Feed as Default> to <Off> (<Scan Settings> <Set Detection of Feeder Multi. Sheet Feed as Default>).
      TIPS
      Determining the top and bottom of the document
      You can set the orientation of the document before scanning so that its top and bottom are positioned correctly when the sent/saved file is displayed on a computer. On the Scan Basic Features screen, press <Options>  <Original Content Orientation>  select <Top at Far Edge> or <Top at Side Edge> when the document is placed vertically or horizontally, respectively  <OK>.
      Specifying multiple destinations including faxes
      Setting <Enable Fax in Scan and Send Function> to <On> enables you to specify fax destinations from the Scan Basic Features screen (<Display Settings> <Display Fax Function>). This setting is useful for specifying multiple destinations including faxes, such as when saving a copy of a sent fax in a file server.
      Checking scanned documents before sending/saving
      You can check scanned documents on the preview screen before sending/saving. Checking Scanned Documents Before Sending/Saving (Preview)
      Registering frequently used settings
      You can combine frequently used destinations and scan settings into a button of the machine for later use. By pressing the registered button when scanning documents, you can quickly complete your settings. Registering Frequently Used Scan Settings
