      0WR6-079
      Checking Status and Log for Scanned Documents
      You can check the statuses and communication logs for sent and saved documents.
      Checking the Statuses for Sent/Saved Documents
      1
      Press .
      2
      Press <Send>  <Job Status>.
      3
      Check the statuses.
      Selecting a document and pressing <Details> enables you to check detailed information such as destinations and the number of pages.
      Selecting a document and pressing <Cancel> enables you to cancel sending/saving.
      Pressing <Print List> prints a status list of sent/saved documents displayed on the screen.
      Pressing <Details>  <Resend> enables you to resend/resave the documents that failed to send/save. To specify another destination, press <Change Destination>. For documents with multiple destinations specified using the same sending/saving method, press <Broadcast List>, select a destination, and then press <Resend> or <Change Destination>.
      You can resend/resave documents when <Delete Failed TX Jobs> is set to <Off>. <Common Settings> <Delete Failed TX Jobs>.
      You can change the destinations of documents that are set to be sent/saved at a specified time as well as documents that failed to send/save. Note that you cannot change the destinations for documents with multiple destinations specified that are being sent/saved, or when entering a new destination is restricted (Restricting New Destinations).
      Checking If Documents Are Sent or Saved Successfully
      1
      Press .
      2
      Press <Send>  <Job Log>.
      3
      Check if documents are sent or saved successfully.
      <OK> is displayed in the <Result> column when a document was sent or saved successfully. If <NG> is displayed, this shows that a document failed to be sent or saved because it was canceled or there was some error.
      Selecting a document and pressing <Details> enables you to check detailed information about the document. A three-digit number in the <Error Code> column on the information represents an error code. You can check the causes and solutions for errors based on error codes. When a Number Preceded by "#" (Error Code) Appears
      Pressing <Communic. Mgt. Report> prints a log list of sent and saved documents displayed on the screen.
