      0WR6-06F
      Sending I-Faxes
      1
      Place the document. Placing Documents
      2
      Press <Scan and Send> on the Main Menu. <Main Menu> Screen
      3
      Specify the destination on the Scan Basic Features screen.  Scan Basic Features Screen
      Specifying Destinations from the Address Book
      Specifying Destinations from One-Touch Buttons
      Entering Destinations Manually
      Specifying Destinations in the LDAP Server
      4
      Press <Options> and specify the scan settings as necessary.
      See the following for details.
      5
      Press .
      Documents are scanned and sending starts.
      To cancel scanning, press <Cancel> or   <Yes>.
      When <Press the [Start] key to scan the next original.> is displayed
      To cancel sending, press <To Status Mntr./Cncl.>  select a document  <Cancel> <Yes>.
      To send with the sender information
      You can send with the sender's name and I-fax address. <Common Settings> <TX Terminal ID>
      To check the statuses for sent documents
      On the <Status Monitor/Cancel> screen, you can check the statuses for sent documents. This screen enables you to send faxes again or cancel sending after checking the statuses. Checking Status and Log for Sent and Received Documents
      To print the report for the results of sending
      On the Scan Basic Features screen, pressing <Options>  <TX Report> enables you to set to automatically print the report listing the results of sending. Checking Status and Log for Sent and Received Documents
      To send files securely
      Using TLS communication enables you to send an encrypted file. Configuring the Key and Certificate for TLS
      When multiple sheets are fed
      Scanning is stopped and the message is displayed on the screen. Follow the message and start operation. To set to not notify with a message, press <Options> on the Scan Basic Features screen <Detect Feeder Multi Sheet Fd.> each time you send a document to disable the setting, or set <Set Detection of Feeder Multi. Sheet Feed as Default> to <Off> (<Scan Settings>  <Set Detection of Feeder Multi. Sheet Feed as Default>).
      TIPS
      Checking scanned documents before sending
      You can check scanned documents on the preview screen before sending.Checking Scanned Documents Before Sending/Saving (Preview)
      Registering frequently used settings
      You can combine frequently used destinations and scan settings into a button of the machine for later use. By pressing the registered button when scanning documents, you can quickly complete your settings. Registering Frequently Used Scan Settings
