      0WR6-012
      Registering the LDAP Server
      In environments where an LDAP sever is employed, fax numbers and e-mail addresses can be searched, specified as destinations from the machine, and registered in the machine's Address Book. Up to five LDAP servers can be registered.
      1
      Press .
      2
      Press <Set Destination>  <Register LDAP Server>.
      3
      Register the LDAP server.
      1
      Press <Register>.
      2
      Enter the necessary information.
      <Server Name>
      Enter a name for the LDAP server.
      <Server Address>
      Enter the IP address or host name of the LDAP server using alphanumeric characters (Example: "ldap.example.com").
      IMPORTANT:
      <Server Address> and DNS
      To prevent errors, pay attention to the following when a destination search is carried out from the machine to the LDAP server.
      When entering the IP address, check if the usable DNS server supports only forward lookup. When the DNS server supports forward lookup only, press <Do Not Use> or <Use> in <Authentication Information> in step 4. When selecting <Use (Security Auth.)>, confirm that the DNS server supports reverse lookup.
      <Position to Start Search>
      Specify where to start searching in the directory tree of the LDAP server.
      For LDAPv3, you can skip the setting because the machine retrieves automatically the server’s setting. For LDAPv2, always specify the point.
      NOTE:
      Entering the format of <Position to Start Search>
      When you use Windows Server 2003 R2 with Active Directory, Windows Server 2008 with Active Directory, or Windows Server 2012 with Active Directory, enter the domain name of the Active Directory in units of strings divided by a dot ".". Add "DC=" for each unit and separate them with commas ",".
      Example: When the domain name is "john.example.com", enter "DC=john,DC=example,DC=com".
      When you use Lotus Notes Domino R7 or later, enter the directory tree node identification name (dn) like "cn=user1,ou=team1,ou=salesdept,o=canon".
      <Use TLS>
      To encode the communication to/from the LDAP server using TLS, press <On>.
      <Port Number>
      Enter the port number used when communicating to/from the LDAP server.
      <Max Addresses to Search>
      Specify how many destinations can be searched.
      <Search Timeout>
      Specify in seconds how long the search can continue.
      3
      Press <Next>.
      4
      Set authentication information.
      Specify authentication methods according to the settings of the LDAP server.
      When authenticating using login information
      Enter the user name and the password used as authentication information.
      When authenticating using encoded data
      Authentication can be done more safely by encoding the data exchange. When this measure is employed, the LDAP version and character code information are set to <ver.3 (UTF-8)>. The time of the machine and LDAP server need to be synchronized.
      When authenticating anonymously without using login information
