Item
Description
<Default Screen after Startup/Restoration>
You can set the default screen displayed at startup.
IMPORTANT:
Depending on the authentication method specified for User Authentication, regardless of the <Default Screen after Startup/Restoration> settings, the Log In screen may appear at startup/restoration.
If <Department ID Management> is set to <On>, the startup screen may differ from the screen set to be displayed as default at startup.
Setting Value
<Main Menu>, <Quick Menu>, <Copy>, <Fax>, <Scan and Send>, <Scan and Store>, <Access Stored Files>, <Fax/I-Fax Inbox>, <Scanner>, <Web Access>, <Tutorial>, <Dest./Fwd. Settings>, <Print>, <Hold>, <Scan for Mobile>
DeviceAdmin: No
NetworkAdmin: No Can be set in the Remote UI: No Device Information Distribution Available: No |
<Default Screen (Status Monitor/Cancel)>
You can change the screen that appears when you press
.Setting Value
<Default Status Type>: <Copy/Print>, <Send>, <Receive>, <Store>, <Consumables/Others>
<Status/Log>: <Job Status>, <Job Log> <Details>: You can select the specific screen if you selected <Copy/Print>, <Send>, or <Receive> in <Default Status Type>. DeviceAdmin: No
<Copy Screen Display Settings>
You can specify the screen that appears when you press <Copy>. Changing the Settings Quickly (Express Copy Screen)
Setting Value
<Regular Copy>, <Express Copy>
DeviceAdmin: No
<Display Fax Function>
You can set the machine to display the Fax function on the Main Menu screen. If you want the fax function to be displayed on the Main Menu screen, you can select whether or not to display the fax function in <Scan and Send>. By displaying the fax function in <Scan and Send>, you can send to various destinations using different sending methods, such as e-mail and I-fax, at the same time.
Setting Value
<Display Fax Function>: <On>, <Off>
<Enable Fax in Scan and Send Function>: <On>, <Off> DeviceAdmin: Yes
NetworkAdmin: Yes Can be set in the Remote UI: No Device Information Distribution Available: No |
<Store Location Display Settings>
You can specify the display settings for the store location that appears when you press <Scan and Store> or <Access Stored Files>.
Setting Value
<Mail Box>: <On>, <Off>
<Advanced Box/Network>: <On>, <Off> <Memory Media>: <On>, <Off> DeviceAdmin: No
<Switch Language/Keyboard>
You can select the language/keyboard displayed on the touch panel display.
Setting Value
<Language>: Select a language from the list.
<Keyboard Layout>: Select a keyboard layout. NOTE:
Some messages may not appear properly in the selected language. In this case, restart the machine.
If Server Authentication + Local Device Authentication are set using personal authentication management, and there is a difference between the language set on the machine and the one set in Active Directory, the sender's full name will not appear in e-mail messages sent to the recipient.
Even if you switch the display language, some display items do not change.
DeviceAdmin: Yes
<Display Switch Language/Keyboard Button>
You can display the button that enables you to swich the language and keyboard layout. The button is displayed in the lower-right of the screen.
Setting Value
<On>, <Off>
DeviceAdmin: Yes
<Use Keyboard Shift Lock Feature>
If you press <Shift> on the keyboard screen, you can enter an uppercase letter. You can specify the shift lock settings for entering uppercase letters continuously or for entering texts which begin with an uppercase letter.
Setting Value
<On>, <Off>
DeviceAdmin: Yes
<Display Remaining Paper Message>
You can set to display a message indicating that the remaining paper loaded in a paper source is low.
Setting Value
<On>, <Off>
DeviceAdmin: Yes
<No. of Copies/Job Duration Status>
The number of copies specified and the approximate time before the current job completes are displayed on the bottom line of the touch panel display.
Setting Value
<On>, <Off>
NOTE:
The accuracy of the approximate times that appear on the bottom line of the touch panel display may vary, depending on the status of the machine.
The approximate time does not appear when the wait time is less than one minute.
DeviceAdmin: Yes
<Paper Type Selection Screen Priority>
You can set whether to prioritize the simple or detailed setting screen when you display the screen to select the paper type.
Setting Value
<Simple>, <Detailed>
DeviceAdmin: Yes
<Switch Millimeter/Inch Entry>
You can set whether to enter numeric values in millimeters or inches on the various numeric entry screens.
Setting Value
<mm>, <Inch>
DeviceAdmin: Yes
<Display Logged-in User Name>
You can display the user name at the bottom of the touch panel display.
Setting Value
<At Screen Top>: <User Name>, <Display Name>
<At Screen Bottom> <Off> DeviceAdmin: No
<Edit Puncher Unit Die Name>
You can change the name of puncher die in the Professional Puncher-A1. This setting can be set when the Professional Puncher-A1 is attached. For more information on the Professional Puncher-A1, consult the instruction manual that comes with it.
Setting Value
<Edit>: Enter the name of punch die.
DeviceAdmin: Yes
NetworkAdmin: No Can be set in the Remote UI: Yes Device Information Distribution Available: No |
<IP Address Display Settings>
You can set whether to display the IP address on the counter information screen.
Setting Value
<On>, <Off>
DeviceAdmin: No
<Display Scan for Mobile>
You can set whether to enable "Scan for Mobile," which is a function to send scanned data to mobile devices such as smartphones and tablets.
Setting Value
<On>, <Off>
DeviceAdmin: No
