      0WR6-0JC
      <Acquire Remote Address Book>
      You can specify the settings to access the Address Book (Remote Address Book) of another imageRUNNER ADVANCE series machine on a network from this machine.
      Item
      Description
      <Acquire Address Book>
      You can select whether to use the Remote Address Book.
      Setting Value
      <On>, <Off>
      DeviceAdmin: Yes
      NetworkAdmin: Yes
      Can be set in the Remote UI: Yes
      Device Information Distribution Available: Yes
      <Remote Address Book Server Address>
      You can specify the IP address or the host name of a device that opens the Remote Address Book externally. The IP address can be specified using IPv4 or IPv6.
      DeviceAdmin: Yes
      NetworkAdmin: Yes
      Device Information Distribution Available: No
      <Communication Timeout>
      You can set the communication timeout. When a device opening a Remote Address Book does not respond within the specified time, the machine stops trying to obtain destinations from the device.
      Setting Value
      15 to 30 to 120 sec.
      DeviceAdmin: Yes
      NetworkAdmin: Yes
      <Fax TX Line Auto Select Adjustment>
      You can set whether to automatically select the fax line instead of using the line registered to the destination, when sending a fax to a destination obtained from a Remote Address Book.
      Setting Value
      <On>, <Off>
      DeviceAdmin: Yes
      NetworkAdmin: Yes
