      0WR6-0UW
      System Options
      By installing system-related options, you can further enhance the performance of the machine.
      imagePASS
      imagePASS is a printer controller which attaches to the back of the machine. imagePASS supports Adobe Genuine PostScript 3 and PCL5e, and is suited for office environments in which larger print volumes are frequently processed, or for users who use Adobe PostScript or other PostScript applications.
      If you are using imagePASS, you cannot use the Encrypted Secure Print Software.
      If you are using imagePASS, you cannot use the Job Hold function.
      Barcode Printing Kit
      This option enables you to print barcodes.
      PCL International Font Set
      This option enables you to add the following fonts for a PCL printer. As a result, you can output using multiple languages in a SAP Unicode environment.
      Andale® and WorldType® Collection J (Japanese Version)
      Andale® and WorldType® Collection K (Korean Version)
      Andale® and WorldType® Collection S (Simplified Chinese Version)
      Andale® and WorldType® Collection T (Traditional Chinese Version)
      In order to support differences in character design depending on the region, four font versions are enabled.
      Super G3 FAX Board
      The "Super G3 FAX Board" enables you to send and receive faxes. You can also send documents that are created in applications directly from your computer via the network.
      The fax driver that enables faxing via a computer is included.
      Super G3 2nd Line Fax Board
      This options adds an additional line to the "Super G3 FAX Board" and enables you to use two lines to send and receive faxes.
      On-Hook is only available with Line 1 (the standard line).
      Super G3 3rd/4th Line Fax Board
      The Super G3 3rd/4th Line Fax Board enables you to use three or four lines to send and receive fax documents.
      Remote Fax Kit
      This option is needed to use the Remote Fax function. Even if the machine is not equipped whit a fax board, you can send faxes via another imageRUNNER ADVANCE machine with a fax board installed on the same network.
      IP FAX Expansion Kit
      Enables you to use IP Fax, a function to send and receive faxes in a TCP/IP network such as an office LAN. As devices send and receive faxes within the network, you can reduce the transmission cost. The transmission speed of IP Fax is faster than conventional fax transmissions.
      Universal Send Trace & Smooth PDF Kit
      This option is useful when using the Send function on the machine. It enables you to convert the text and line drawings of a scanned image to scalable outline data. The outline data (Trace) can be extracted and used in Adobe Illustrator. The smoothing process can also be applied to the text of the outline data to make it appear less jagged when viewed on a computer monitor or in print.
      Universal Send Security Feature Set
      The Universal Send Security Feature Set enables you to use the Send function on the machine with security. It enables you to send documents in the following formats.
      Encrypted PDF
      The Encrypted PDF mode enables you to encrypt PDF files that you send to an e-mail address or file server for enhanced security. Only users who enter the correct password can open, print, or change the received PDF.
      Device Signature PDF or Device Signature XPS
      This is a PDF or XPS file with a unique device signature. The device signature enables the recipient of the PDF or XPS file to determine which device generated the file.
      Universal Send Digital User Signature Kit
      This option enables you to use the Send function on the machine with security. It enables you to send a PDF or XPS file with a unique digital user signature obtained from a certificate authority. This enables the recipient of a PDF or XPS file to verify which user signed it.
      Secure Watermark
      The Secure Watermark mode enables you to embed hidden text in the background of copies. You can embed text, such as "CONFIDENTIAL," the date and time, or a department name. The embedded text only appears when the machine prints the copies.
      Voice Guidance Kit
      This option enables you to hear voice navigation instructions when operating the machine.
      Voice Operation Kit
      The Voice Operation Kit enables you to hear voice navigation instructions when operating the machine. The Voice Operation Kit also includes a voice recognition function, which enables you to set the various functions of the machine using your own voice.
      Document Scan Lock Kit
      This option enables you to embed hidden user information or copy restriction information in the output when documents are copied/printed and reduce the risk of confidential information being leaked. It helps you to restrict scanning of the document (Scan Lock function) and identify the user that output the document (Tracking function). You can embed a QR code/TL code.
      Web Access Software
      The Web Access Software enables you to view Web pages from the touch panel display of the machine. You can print PDF files on Web pages without using a computer. Moreover, if you create a Web page or special content, you can share PDF documents with other users. For information on how to use the Web Access, see Web Access.
      This option enables you to encrypt print data sent from a computer using the Secure Print function, and decrypt it at the machine. This enables you to strengthen the security of print data by preventing the contents of your printed documents from being seen by other users, and preventing the unauthorized use of confidential information.
      2.5inch/250GB HDD
      The 2.5inch/250GB HDD is necessary when using the Mirroring function of the HDD Mirroring Kit.
      2.5inch/1TB HDD
      By replacing the hard disk installed in the machine with the 2.5inch/1TB HDD, you can expand the memory capacity of the machine to 1 TB. Once you replace the hard disk with the 2.5inch/1TB HDD, the additional 2.5inch/1TB HDD is required to back up the data by using the HDD Mirroring Kit.
      HDD Mirroring Kit
      The HDD Mirroring Kit enables you to back up the data on the hard disk of the machine to the additional optional HDD. Even if one fails, you can access the other hard disk.
