<Function Settings>
<Common>
<Paper Feed Settings>
<Function Settings>
<Common>
<Function Settings>
<Common>
<Function Settings>
<Common>
The settings for Automatic Paper Selection and Auto Drawer Switching are disabled for paper sources with <Print Side Priority> set. The print speed is also slower when performing one-sided printing.
<Function Settings>
<Common>
If a job is suspended because paper has run out during the job, the next job is not processed even after the designated suspension time elapses.
To automatically delete suspended jobs, see <Auto Delete Suspended Jobs>.
<Function Settings>
<Common>
<Paper Output Settings>
If a certain tray reaches its stacking limit, the machine automatically uses another tray that is designated for the same function. However, it is recommended that you only designate one tray for fax/I-fax documents to prevent them from getting lost.
Select <Other> when printing reports.
The priority order of the output destinations is determined by the order of the selected output trays. The priority is displayed as "1," "2," and "3."
Paper sizes which can be output to each output tray differ depending on optional equipment attached to the machine, such as the finisher, etc. For more information, see Optional Equipment.
<Function Settings>
<Common>
<Function Settings>
<Common>
<Function Settings>
<Common>
You cannot insert job separation sheets between copy sets in the following cases:
If you are using the Group, Booklet, Saddle Stitch, or Fold mode, or if you are using tab paper |
<Function Settings>
<Common>
For information on printing using tab paper, see Loading Tab Paper.
<Function Settings>
<Common>
For information on printing using stapling, see Finishing with the Stapler.
<Function Settings>
<Common>
<Print Settings>
If the same printing priority has been specified for multiple functions, printing starts with the first processed print job.
Priority printing does not take place until the current job is complete. However, if the current job is paused, the printing of another job may start, depending on its settings.
<Function Settings>
<Common>
<Print Settings>
<Function Settings>
<Common>
<Print Settings>
<Output Report Default Settings>
<Function Settings>
<Common>
<Print Settings>
Make sure you place the original that contains the image form on the platen glass. It is not possible to scan an image form from the feeder.
For information on the Superimpose Image function, see Superimposing Images.
<Function Settings>
<Common>
<Print Settings>
<Function Settings>
<Common>
<Print Settings>
For information on <Watermark> in <Secure Watermark>, and <Page Numbering> and <Watermark> when copying, see Attaching Numbers and Symbols to Copies and Embedding the "TOP SECRET" Text (Secure Watermark).
<Function Settings>
<Common>
<Print Settings>
<Function Settings>
<Common>
<Print Settings>
IPv6 addresses cannot be printed.
<Function Settings>
<Common>
<Print Settings>
<Secure Watermark/Document Scan Lock>
The Document Scan Lock mode does not guarantee restriction of unauthorized copying. You may not be able to restrict unauthorized copying or analyze tracking information, depending on the combination of settings and the output, such as a document with an image on the entire page.
<Function Settings>
<Common>
<Print Settings>
If <Printer Driver Secure Watermark> and <Forced Secure Watermark> are set for a printer at the same time, Forced Secure Watermark is given priority.
If a login service has been set, the user name/Department ID of the user who logged in is printed.
The watermark <CONFIDENTIAL> is printed if a login service is not set.
To use this function, specify the following settings in the printer driver in advance. For details, see the help for the printer driver.
<Function Settings>
<Common>
<Print Settings>
Load A3, A4, LTR, or 11" x 17" size plain or heavy paper when making sample prints.
<Function Settings>
<Common>
<Print Settings>
<Function Settings>
<Common>
<Print Settings>
<Function Settings>
<Common>
<Print Settings>
<Function Settings>
<Common>
<Print Settings>
To retain a suspended job without automatically deleting it, see <Suspended Job Timeout>.
<Function Settings>
<Common>
<Scan Settings>
Direct sending of faxes does not support this setting. If a paper jam occurs while performing direct sending, the job will be canceled. In this case, set the job again.
Depending on the location of a paper jam, it can be difficult to determine
whether document scanning has been completed. If you have set <From Suspnd. Original> for <Feeder Jam Recovery Method> and you do not find until which page the document has been scanned, it is recommended that you cancel the job, and then execute it again. |
<Function Settings>
<Common>
<Scan Settings>
<Function Settings>
<Common>
<Scan Settings>
<Function Settings>
<Common>
<Scan Settings>
When <On> is selected, extremely thin lines may be detected as streaks.
<Function Settings>
<Common>
<Scan Settings>
<Function Settings>
<Common>
<Scan Settings>
<Function Settings>
<Common>
<Scan Settings>
<Function Settings>
<Common>
<Scan Settings>
When the remote scanner function is enabled, you cannot use <Copy> and <Scan and Store>.
You can specify the time period in which you are logged out and the touch panel display returns to the default setting automatically.
<Function Settings>
<Common>
<Scan Settings>
If <Auto Reset Time> is set to 0, the machine automatically goes offline after approximately two minutes.
<Function Settings>
<Common>
<Generate File>
This setting is disabled when sending a fax or I-fax.
If you scan an original with many colors when <Text> is selected for the original type, the data size and image quality will vary following compression, according to the selected image level. However, if the original is in monochrome or has few colors, it does not matter which image level you select.
<Function Settings>
<Common>
<Generate File>
<Function Settings>
<Common>
<Generate File>
You cannot use the Auto (OCR) in File Name mode and the Encrypted PDF mode at the same time when sending a file.
<Function Settings>
<Common>
<Generate File>
If you increase the value in <Graphics Recognition Level>, the data size also increases. It is recommended that you first use <Normal>, and if desirable results are not obtained, try increasing the recognition level to <Moderate> or <High>.
<Function Settings>
<Common>
<Generate File>
<Function Settings>
<Common>
<Generate File>
<Function Settings>
<Common>
<Generate File>
Depending on the functions set for the PDF files, the version assigned may be higher than that specified with this setting.
<Function Settings>
<Common>
<Generate File>
The following PDF functions cannot be set if <Format PDF to PDF/A> is set to <On>.
Encryption
Reader Extensions
Visible Signature
<Function Settings>
<Common>
<Generate File>
If you set <Optimize PDF for Web> to <On>, this setting can be used with one of the following settings:
Reader Extensions
Device Signatures
User Signatures
<Function Settings>
<Common>
<Generate File>
<Function Settings>
<Common>
<Generate File>
Adobe LiveCycle Rights Management ES series software is required to use this setting. For more information, contact your local authorized Canon dealer.
To use this setting, the Adobe LiveCycle Rights Management server and this machine must be connected via the Internet or an intranet.
For information on the IP address, host name, and port number, contact the administrator of the Adobe LiveCycle Rights Management server.
For instructions on generating a PDF file using a Rights Management server, see Adding a Digital Signature to Sent Files.
<Function Settings>
<Common>
<Doc. Scan Lock Operation Settings>
<Function Settings>
<Common>
If you convert a document with a TL code embedded to a generic file format (such as PDF and TIFF) using the functions described in <Scan and Send> or <Scan and Store>, the embedded information is not retained. Therefore, when you print the file after it has been converted, the settings in <Doc. Scan Lock Operation Settings> are not reflected.
You can analyze the embedded information using the Document Scan Code Analyzer for MEAP that is supplied with the Document Scan Lock Kit. For more information, see the manual for Document Scan Code Analyzer for MEAP.
<Function Settings>
<Common>
<Function Settings>
<Common>
<Set Authentication Method>
<Device Login Authentication Information> is available only when using the same authentication information for logging in to the machine and accessing the LDAP server, and when using a login service which supports Integrated Authentication. For information whether the login service you are using supports Integrated Authentication, contact your local authorized Canon dealer.
<Function Settings>
<Common>
<Function Settings>
<Common>
<Function Settings>
<Common>
