The administrator can restrict the copying of documents by forcibly embedding scan lock information in documents when they are printed or copied. Tracking information can also be embedded, enabling you to analyze who, when, and which machine was used to output the document. This information is embedded in TL code or QR code in documents. A system option is required in order to use this function. System Options
Original
Output (with TL code)
Prohibit copying/
Embed tracking information |
If tracking information is included in the TL code, you can analyze the tracking information to check the data embedded in the TL code, such as the date, user name, and device name.
It is also possible to only embed the tracking information without restricting copying.
Original
Output (with QR code)
Prohibit copying/
When using QR code to embed the scan lock information, the tracking information is also embedded automatically. You can analyze the tracking information to check the data embedded in the QR code, such as the date, user name, and device name. In addition, the tracking information is updated each time the document is copied, enabling you to analyze the information for the most recent copy operation.
It is also possible to only embed the tracking information without prohibiting copying.
<Function Settings>
<Common>
<Document Scan Lock Operational Settings>
<Use Document Scan Lock>
Select <Use TL Code> or <Use QR Code>
<OK>
<Apply Set. Changes>
<Yes>
You can also set the Document Scan Lock mode when printing from the printer driver. <Printer Driver Watermark/Document Scan Lock>
