Attaching Numbers and Symbols to Copies
You can attach page numbers, management numbers, or dates, etc. when copying. You can also attach stamps which read "Confidential," etc. This allows for easier management in situations such as when you distribute multiple copies of documents.
1
Place the original.
Placing Originals
2
Press <Copy> on the Main Menu.
<Main Menu> Screen
3
Press <Options> on the Copy Basic Features screen.
Copy Basic Features Screen
4
Press <Page Numbering>, <Copy Set Numbering>, <Watermark>, or <Print Date>.
5
Select the printing format.
There are no settings to select if you specified <Copy Set Numbering>, <Watermark>, or <Print Date> in step 4. Proceed to step 6.
6
Select the printing position.
Finely adjust the page number position
In <Set Details>, you can adjust the printing position and change the print position when performing two-sided printing.
Enter a positive (+) value for X to move the printing position to the left, or a minus (-) value for Y to move the printing position upward.
Press <Set Details>, specify each setting, and press <OK>.
7
Select the orientation of the placed original.
As shown in the illustrations below, if the original is placed in the portrait orientation when facing you, select <Upright Image>, if placed in the landscape orientation, select <Sideways Image>.
<Upright Image>
<Sideways Image>
8
Specify the content to print.
9
Press <OK>
<Close>.
10
Press
Copying starts.
Copy set numbers are printed on all copied pages.
LINKS
