You can configure the machine to forcibly print TL code on copied or printed documents, to prevent them from being copied. Select whether to print the TL code on copied or printed documents, and specify the information to embed.
Some multifunctional printer settings may allow documents to be printed or copied even though duplication is restricted with scan lock information. <Doc. Scan Lock Operation Settings>
<Document Scan Lock TL Code Settings> |
<Common>
<Print Settings>
<Document Scan Lock Settings>
<Forced Document Scan Lock>.
<Forced Secure Watermark/Document Scan Lock> instead of <Document Scan Lock Settings>
<Prohibit All>
<OK>.
Setting the tracking information
1
Press <Tracking Information>.
2
Select <Set>, configure the necessary settings, and press <OK>.
![]() <Custom Characters>In addition to embedding information such as Department ID/user name, date/time, and device name, you can also add custom text.
<Password When Analyzing Embedded Info.>To require a password when using the information analysis tool to analyze the tracking information, press <Set> and specify a password. The factory default setting for this password is "7654321". It is recommended that you change the password.
<Allow All>
<OK>. A TL code that allows copying is printed on the document.
You can adjust the size and density of the dots used in the TL code. Try adjusting these settings if the information embedded in the TL code cannot be read properly. <Secure Watermark/Doc. Scan Lock>
<Adjust TL Code> |
