Optional Equipment
By combining options, you can use functions more efficiently.
When the Staple Finisher-Y1/Booklet Finisher-Y1 is installed
Booklet Finisher-Y1
You can perform collating, grouping, stapling (Corner/Double/Saddle Stitch), and saddle folding with this option. In addition, you can manually bind with the stapler or bind without the stapler. Staple Finisher-Y1/Booklet Finisher-Y1/Buffer Pass Unit-L1/2/3 Hole Puncher Unit-A1
Buffer Pass Unit-L1
Feeds paper to the finisher.Staple Finisher-Y1/Booklet Finisher-Y1/Buffer Pass Unit-L1/2/3 Hole Puncher Unit-A1
Cassette Feeding Unit-AM1
Load the type of paper that you frequently use. You can load paper that cannot be loaded in the paper drawer 1, such as A3 and custom size paper. Cassette Feeding Unit-AM1
Staple-P1 (saddle stitcher unit staple cartridge)
This option is a staple cartridge for the saddle stitcher unit which can be installed in the "Booklet Finisher-Y1." Replacing the Staples (Optional)
If you install the "2/3 Hole Puncher Unit-A1" in the "Staple Finisher-Y1" or "Booklet Finisher-Y1," you can punch holes in your printouts. Staple Finisher-Y1/Booklet Finisher-Y1/Buffer Pass Unit-L1/2/3 Hole Puncher Unit-A1
Staple Cartridge-Y1 (stapler unit staple cartridge)
This option is a staple cartridge for the stapler unit which can be installed in the "Staple Finisher-Y1" and "Booklet Finisher-Y1." Replacing the Staples (Optional)
Staple Finisher-Y1
You can perform collating, grouping, and stapling (Corner/Double) with this option. In addition, you can manually bind with the stapler or bind without the stapler. Staple Finisher-Y1/Booklet Finisher-Y1/Buffer Pass Unit-L1/2/3 Hole Puncher Unit-A1
When the Inner Finisher-H1 is installed
Inner Finisher-H1
You can perform collating, grouping, and stapling (Corner/Double) with this option. In addition, you can manually bind with the stapler or bind without the stapler. Inner Finisher-H1/Inner 2/4 Hole Puncher-B1/Inner 2/3 Hole Puncher-B1
If you install the "Inner 2/4 Hole Puncher-B1" or "Inner 2/3 Hole Puncher-B1" in the "Inner Finisher-H1," you can punch holes in your printouts. Inner Finisher-H1/Inner 2/4 Hole Puncher-B1/Inner 2/3 Hole Puncher-B1
This option is a staple cartridge for the stapler unit which can be installed in the Inner Finisher-H1." Replacing the Staples (Optional)
When Other Options are Installed
Copy Card Reader-F1
You can implement Department ID Management using the card reader. Copy Card Reader-F1
Paper Deck Unit-F1
If you install the "Paper Deck Unit-F1" to the machine, you have an additional large-capacity paper source. Paper Deck Unit-F1
High Capacity Cassette Feeding Unit-A1
If you install the "High Capacity Cassette Feeding Unit-A1" to the machine, you have an additional large-capacity cassette. High Capacity Cassette Feeding Unit-A1
Utility Tray-B1
This option provides space for placing originals.
Printer Cover-J1
Install this option if you use the machine as a printer. Printer Cover-J1
Inner 2way Tray-J1
This option enables paper to be output to two locations. If you have installed the Copy Tray-J2, paper can be output to three locations. Inner 2way Tray-J1
Platen Cover Type W
This option holds the original placed on the platen glass in place. Platen Cover Type W
Copy Tray-J2
Install this to use finishing modes such as Collate, Group, and Rotate 90 Degrees. Copy Tray-J2
Tab Feeding Attachment Kit-F1
Attach the "Tab Feeding Attachment Kit-F1" to load tab paper into the paper drawer of the machine. This option can only be attached to the Paper Drawer 2, and holds only A4 tab paper.
For information on the combination of options that can be installed on the machine, contact your local authorized Canon dealer.
13WJ-0HE
