To use Area Designation (Framing) with the Image Repeat mode, first specify the Image Repeat mode, and then designate the desired area. Only one area can be designated.
The designated area is too small, the color original may be scanned in the Black mode even if the color mode is set to [Auto (Color/Black)].
You cannot use the Area Designation mode for images that have already been stored in a mail box. This mode is available only when you scan an image for the first time using the Mail Box function.
You can use the numeric keys to modify areas designated with the edit pen.
If you designate an area using the edit pen, the output image may not reflect the designated area precisely. To designate an area precisely, enter the values using the numeric keys.
This mode is only available for storing files in the Mail Box.
You can designate only one polygonal area at a time.
You cannot designate a rectangular area and a polygonal area at the same time.
You cannot scan documents with the Area Designation mode if you place your originals in the feeder.
Confirm that the original is placed on the platen glass.
To clear the last point entered, press [Delete Point]. (Once an area is designated, [Delete Point] changes to [Clear Area].)
To clear a designated area, press [Clear Area].
To zoom in on any area on the original, press the zoom ratio drop-down list → select an enlargement ratio → press [
If you select [Enter Multipoints], only one area can be designated at a time.
An area that is designated by selecting [Enter Multipoints], cannot be modified using
[Framing]:
Stores only the contents of the designated area while discarding the rest of the original.
[Blanking]:
Stores the original by blanking out the contents of the designated area.
If the designated area is rectangular, and you want to continue designating other areas, repeat steps 6 to 8. Areas that have already been designated are displayed with the new area.
To modify a designated area that was specified using the edit pen, press [Fine Adjust] → [Select Point] until the screen displays the desired point that you want to modify → press [
Before performing the next step, you must manually measure the size and position of the area that you want to designate on the original.
When you measure the XY values, always start measuring from the image out to the right side edge of the original, and up to the top of the original. These measurements tell the machine the desired framed area's size and position.
[X1]:
The distance of the area's right border to the original's right edge.
[X2]:
The distance of the area's left border to the original's right edge.
[Y1]:
The distance of the area's top border to the original's top edge.
[Y2]:
The distance of the area's bottom border to the original's top edge.
To change a value you entered, press [X1], [X2], [Y1], or [Y2] → enter the correct value using
![]() ![]() To check the designated area, press [Check Area].
[Framing]:
[Blanking]:
To continue designating other areas, press an area key → repeat step 5.
To redesignate an area, select the area by pressing the appropriate area key.
To clear a designated area, select the area by pressing the appropriate area key → press [Clear Area].
If you want to use different settings for different areas, select the area by pressing the appropriate area key → select [Framing], or [Blanking].
