Top » Scan and Store » Storing Originals While Printing
06RH-12S
You can scan and store an original while the machine is printing (for example while it is processing a print job, or printing from [Access Stored Files]).
As an example, the procedure for selecting a mail box as the storage location is explained in this section.
Press [Close] on the screen that appears while the machine is printing.
Place your originals → press (Main Menu).
Press [Scan and Store] → [Mail Box].
4.
Select the desired Mail Box → press [Scan].
5.
Specify the desired scan settings.
6.
Press (Start).
You can change the (time-coded) assigned name after you scan the file. (See "Checking File Information.")
