Category
Top » Remote UI » Managing Inboxes » Managing Confidential Fax Inboxes
Category Top
Overview of This Function
System Requirements
Before You Start the Remote UI
Starting the Remote UI
The Portal Page of the Remote UI
Managing Jobs
Managing Copy/Print Jobs
Managing Send and Receive Jobs
Managing Store Jobs
Device Status and Information Display
Shutting Down the Machine from the Remote UI
Restarting the Machine
Registering/Editing Custom Paper Types
Specifying a File Name for Transmission to a Destination in Favorite Settings
Forwarding Settings
Specifying the Advanced Box Settings
LDAP Server Settings
Import/Export Function
Loading Address Lists and Device Settings Information (Import)
Saving Address List and Device Settings Information to a Computer (Export)
Managing Department IDs
Installing a Certificate File
Displaying/Clearing the Message Board
Audit Log Management
Backing Up Stored Data
Managing the Address Lists
Managing Inboxes
Managing Mail Boxes
Managing the Memory RX Inbox
Printing Files Directly From the Remote UI
Available Administrator Settings Table (Remote UI)
Collapse all|Expand all
Click [Access Received/Stored Files] → [Confidential Fax Inbox] → select the number of the desired inbox.
If the desired inbox is set with a PIN, enter the PIN → click [OK].
You can also select the desired inbox by entering its number next to <Box Number (00-49)> → click [Open...].
Change the settings of the selected Confidential Fax Inbox, or select an operation to be performed for a document in the Confidential Fax Inbox.
To change the settings of the selected Confidential Fax Inbox:
To print documents:
To delete documents:
To display the details of a document:
Click [Settings] → specify the desired settings → click [OK].
For more information on the Confidential Fax Inbox settings, see "Confidential Fax Inbox."
To print documents:
Select the documents that you want to print → click [Print] → [Start Printing].
If you want the documents to be automatically deleted after they are printed, select [Delete File After Printing].
Select the documents that you want to delete → click [Delete].
Once a document is deleted, it cannot be retrieved.
Click the destination.
You can also click an icon in Type to display the document details.
Displayed Icons:
Forwarded fax document or fax document saved in memory.
Forwarded I-fax document or I-fax document saved in memory.
