Category
Top » Remote UI » Starting the Remote UI
Category Top
Overview of This Function
System Requirements
Before You Start the Remote UI
The Portal Page of the Remote UI
Managing Jobs
Managing Copy/Print Jobs
Managing Send and Receive Jobs
Managing Store Jobs
Device Status and Information Display
Shutting Down the Machine from the Remote UI
Restarting the Machine
Registering/Editing Custom Paper Types
Specifying a File Name for Transmission to a Destination in Favorite Settings
Forwarding Settings
Specifying the Advanced Box Settings
LDAP Server Settings
Import/Export Function
Loading Address Lists and Device Settings Information (Import)
Saving Address List and Device Settings Information to a Computer (Export)
Managing Department IDs
Installing a Certificate File
Displaying/Clearing the Message Board
Audit Log Management
Backing Up Stored Data
Managing the Address Lists
Managing Inboxes
Managing Mail Boxes
Managing the Memory RX Inbox
Managing Confidential Fax Inboxes
Printing Files Directly From the Remote UI
Available Administrator Settings Table (Remote UI)
Collapse all|Expand all
To start the Remote UI, follow the procedure described below.
The portal page appears when you start the Remote UI. You can check the current status of the device on the portal page.
Start your Web browser → enter the following URL in the address bar.
http://<IP address or host name of the machine>/
If the Remote UI does not start properly and an error message appears, delete the cache files of your Web browser.
If you are logging in as an administrator, enter the System Manager ID and System PIN → press [Administrator Login]. If you are a general user, click [General User Login] without entering an ID or PIN.
When a login service is not set
To be able to log in using SSO-H, it is necessary to match the current time on the computer in which Active Directory is running and the computer to log in with. If there is more than a 30 minute difference in the current time set in the computers, an error occurs when you log in using SSO-H.
If Default Authentication and Department ID Management are set, enter the Department ID and password to log in.
SSO-H performs authentication for users registered in Active Directory.
You can use only alphanumeric characters,- (hyphen), or _ (underscore) for a user name for SSO-H authentication. You can log in only if you use valid characters.
You can select up to 200 trusted domain names in addition to the domain name the machine belongs to for the DNS Domain Name of SSO-H.
Default Authentication and SSO-H cannot be used simultaneously.
