After registering the license for the Direct Print Kit, make sure you restart the machine and perform the procedure in "Reset Printer." The Direct Print function is only activated when the license has been registered, the machine has been restarted, and the printer settings have been initialized.
The touch panel display settings for use with Direct Print are 'Common Settings', 'Imaging Settings', 'PDF Settings', and 'XPS Settings'. For more information on the settings for 'Common Settings', 'Imaging Settings', 'PDF Settings', and 'XPS Settings', see "Function Settings: Printer."
The Direct Print Kit (for PDF/XPS) or PS Printer Kit is required to print a PDF file without opening it.
If you attempt to print a file without entering the password, the message <PDL PDF Data Decode Err> is displayed, and printing is canceled. To print PDF files that forbid printing, or to print PDF files that only allow low-resolution printing in high resolution, enter the master password.
To print by specifying a URL, it is necessary to set [Use Reference Print] to 'On' in [Remote UI] in [Management Settings] (Settings/Registration).
If you specify to print a PDF file by entering its URL, the next print job cannot be processed until the download of the PDF file is complete or until the browser has disconnected from the Web server.
Only the HTTP protocol is supported for the printing of a PDF file by entering its URL.
Resolution
You can set the resolution for printing.
Resolution is expressed in units of dpi (dots per inch). The larger this value, the higher the resolution, and the finer the detail of the image.
If you select [600 dpi], files are printed at 600 dpi resolution. This mode is optimal for normal documents and tables.
If you select [1200 dpi], files are printed at 1200 dpi resolution.
Halftones
This setting specifies how to express halftones.
Settings can be applied separately for text, graphics, and image data.
The Gradation mode enables you to print combining smooth gradation with image sharpness. You can adjust this setting to smoothly print shapes and graphs using gradation.
The Resolution mode enables you to print files with the contours of text data and other fine lines clearly reproduced. This mode is optimal for printing data containing a lot of text or fine lines.
The High Resolution mode enables you to print in even finer detail than the Resolution mode. You may however experience a slight drop in the integrity of the image quality. This setting is optimal for printing files containing text and very fine lines or CAD data with sharpness and clarity.
The setting for [High Resolution] is invalid in the following cases (processed using [Resolution]):
[High Resolution] is not set for text, graphics, and image data
[Resolution] is set to '1200 dpi'
Grayscale Conversion
This setting is used to convert color data to black-and-white data.
This setting is invalid for monochrome data.
If you select [Use Auto (Color/Black)] or [Full Color] for the Color Mode setting, this setting is invalid.
Dot Gain Adjustment
This setting can be used to adjust the area to fill and the density of halftone dots. The larger the value, the more dense the dots.
No. of Copies
You can set the number of prints.
Paper Size
Set the paper size to output.
If you select [Auto], the optimal paper source is selected according to the page size of the PDF file, and the file is printed.
If you select a setting other than [Auto], the file is printed so that the long side of the PDF file page size and the long side of the selected paper size are in the same direction.
If the page size of the PDF file exceeds the maximum or minimum size for custom paper, the job is canceled (jobs that have already been sent are not counted).
Paper Type
Set the paper type to output.
Feed Manually
You can fix the multi-purpose tray as the paper source.
Enlarge/Reduce to Fit Paper Size
By selecting this setting, the aspect ratio is fixed and the image is enlarged or reduced according to the printable area of the selected paper size. However, if you set [Auto] for Paper Size, this setting is invalid.
Enlarge Print Area
This setting enables you to enlarge the print area.
Print 2-Sided
You can select whether to perform one-sided or two-sided printing.
Binding Location
You can set whether to position the gutter on the long edge or short edge of the paper. If a gutter has been set from the touch panel display, the Gutter position is automatically adjusted for each side of the paper.
N on 1
You can print multiple pages of a PDF file on one sheet of paper.
*To print multiple pages on one sheet, set [Paper Size] to a setting other than [Auto].
Page Order
You can set the order to position the pages when printing multiple pages of a PDF file on one sheet of paper in the Page Layout settings.
Finishing*
You can set whether to print by pages of a job or by job sets.
If you set [Off], the specified number of print sets are output by page.
If you set [Collate (Page Order)], the specified number of print sets are output in page order.
If you set [Group (Same Pages)], the specified number of print sets are output by page.
If you set [Staple], the print sets are output in page order, and stapled.
Offset*
If you select the check box and set [Collate (Page Order)] for <Finishing>, the specified number of print sets are output in page order, and each print set is slightly offset in the output tray.
If you select the check box and set [Group (Same Pages)] for <Finishing>, the specified number of print sets are output by page, and each page set is slightly offset in the output tray.
Rotate 90 Degrees*
If you select the check box and set [Collate (Page Order)] for <Finishing>, the specified number of print sets are output in page order, and each print set is output in alternating directions.
If you select the check box and set [Group (Same Pages)] for <Finishing>, the specified number of print sets are output by page, and each page set is output in alternating directions.
Punch Position*
This setting enables you to punch two holes in a print. Select the check box → select [Left], [Right], [Top], or [Bottom].
If you set the Staple and Hole Punch modes at the same time, make sure the position settings for the two modes match each other. If the positions do not match (e.g. the stapling position is set to the right, while the position of the punch holes is set to the left), both settings become invalid and printing is performed without either mode.
Staple Position*
If you set [Staple] for <Finishing>, you can specify the stapling position.
If you select [Corner], you can set [Top Left], [Top Right], [Bottom Left], or [Bottom Right].
If you select [Double], you can set [Left], [Right], [Top], or [Bottom].
Booklet
This setting enables you to fold sheets in half to create a booklet layout, and print two pages of data on each side of a sheet of paper. If you do not set [Saddle Stitch], the Fold Only setting is used.
Saddle Stitch
You can set whether to staple the sheets in the center and fold them using the roller when printing a booklet.
Opening Direction
If you select [Booklet], select [Left Opening] or [Right Opening].
If you set [Left Opening], the pages are printed in a layout to create a booklet that opens to the left.
If you set [Right Opening], the pages are printed in a layout to create a booklet that opens to the right.
Print Comments
You can set whether to print the comments for a PDF file.
If you set [Off], the comments are not printed.
If you set [Auto], only comments specified within the PDF file are printed.
Store in Mail Box
To store a file in a mail box, select [Store in Mail Box] → select the desired mail box. Enter the desired name for the data to store in the mail box in <File Name After Storing>. You can enter up to 24 characters.
To restore the default settings, click [Restore Defaults].
Do not repeatedly click [Start Printing] when a file is being forwarded. It may take some time for a file to be forwarded. However, if you click repeatedly during forwarding, the file may malfunction and may not be forwarded.
To print PS/EPS files directly from the Remote UI, it is necessary to activate the PS Printer Kit.
Resolution
If you select [1200 dpi], files are printed at 1200 dpi resolution. This enables you to reproduce the contours of text and graphics in fine detail. This mode is optimal for printing data including fine and/or faint lines.
No. of Copies
Print 2-Sided
Finishing*
The [Offset] mode enables you to set how prints are output. Select [Offset] → [Finishing].
If [Collate (Page Order)] is set, the specified number of print sets are output in page order, and each print set is slightly offset in the output tray.
If [Group (Same Pages)] is set, the specified number of print sets are output by page, and each page set is slightly offset in the output tray.
The [Punch] mode enables you to punch holes in a print. Select [Punch] → select [Punch Position] or [Punch Type].
- If you select [Punch Position], you can set [Left], [Right], [Top], or [Bottom]. - If you select [Punch Type], you can set [Finisher Puncher (2 Hole)]. You can set [Corner] or [Double] for [Staple Position.
- If you select [Corner], you can set [Top Left], [Top Right], [Bottom Left], or [Bottom Right]. - If you select [Double], you can set [Left], [Right], [Top], or [Bottom]. If you set the Staple and Hole Punch modes at the same time, make sure the position settings for the two modes match each other. If the positions do not match (e.g. the stapling position is set to the right, while the position of the punch holes is set to the left), both settings become invalid and printing is performed without either mode.
Store in Mail Box
Resolution
Resolution is expressed in units of dpi (dots per inch). The larger this value, the higher the resolution, and the finer the detail of the image. If you select [600 dpi], files are printed at 600 dpi resolution. This mode is optimal for normal documents and tables.
No. of Copies
Paper Size
Paper Type
Image Orientation
You can select whether to print the image vertically or horizontally.
Print Position
You can set the position to print the image.
Zoom Mode
You can set whether to enlarge or reduce an image for printing. If you select [Auto], the machine automatically enlarges/reduces the image according to the printable area of the paper.
Enlarge Print Area
Print 2-Sided
Binding Location
Show Warnings
You can select the method to process a job when an error is detected for an Imaging function.
If you select [On], the error is displayed on the touch panel display.
If you select [Off], the error is not displayed and the job is processed.
Halftones
[Gradation] enables you to print combining smooth gradation with image sharpness. You can adjust this setting to smoothly print shapes and graphs using gradation.
[Resolution] enables you to print files with the contours of text data and other fine lines clearly reproduced. This mode is optimal for printing data containing a lot of text or fine lines.
[High Resolution] enables you to print in even finer detail than [Resolution]. You may however experience a slight drop in the integrity of the image quality. This setting is optimal for printing files containing text and very fine lines or CAD data with sharpness and clarity.
You can select the method for converting color data to grayscale for printing.
If you select [sRGB], grayscale values are calculated using the sRGB standard color conversion method.
If you select [NTSC], grayscale values are calculated using the NTSC standard color conversion method.
If you select [Uniform RGB], the average color values for Red, Green, and Blue are used for the grayscale values.
You cannot print images files in the JPEG 2000 format.
The encoding methods for JPEG data that are supported/not supported by this machine are as follows:
Supported
Standard DCT method
Not Supported
Extended DCT method
Lossless method
Hierarchical method
The encoding methods for TIFF data that are supported/not supported by this machine are as follows:
Supported
Uncompressed
ITU-T Rec. T.4 One-dimensional encoding method
ITU-T Rec. T.4 Two-dimensional encoding method
ITU-T Rec. T.6 Basic facsimile encoding method
ITU-T Rec. T.81 JPEG (Standard DCT method only)
PackBits (Apple Macintosh PackBits method)
Not Supported
LZW
ITU-T Rec. T.82 JBIG (black-and-white)
ITU-T Rec. T.43 JBIG (color)
ITU-T Rec. T.44 MRC
The Direct Print Kit (for PDF/XPS) is required to print a XPS file without opening it.
Resolution
Halftones
In the cases below, the setting for [High Resolution] is invalid. ([Resolution] is used.)
If [High Resolution] is not set for text, graphics, and image data
If you set [1200 dpi] for [Resolution]
No. of Copies
Paper Size
If you select [Auto], the optimal paper source is selected according to the page size of the XPS file, and the file is printed.
If you select a setting other than [Auto], the file is printed so that the long side of the XPS file page size and the long side of the selected paper size are in the same direction.
If the page size of the XPS file exceeds the maximum or minimum size for custom paper, the job is canceled (jobs that have already been sent are not counted).
Paper Type
Feed Manually
Enlarge Print Area
Print 2-Sided
Binding Location
N on 1
You can print multiple pages of an XPS file on one sheet of paper.
*To print multiple pages on one sheet, set <Paper Size>to a setting other than [Auto].
Finishing*
Offset*
If you select the check box and set [Collate (Page Order)] for <Finishing> the specified number of print sets are output in page order, and each print set is slightly offset in the output tray.
If you select the check box and set [Group (Same Pages)] for <Finishing> the specified number of print sets are output by page, and each page set is slightly offset in the output tray.
Rotate 90 Degrees*
If you select the check box and set [Collate (Page Order)] for <Finishing> the specified number of print sets are output in page order, and each print set is output in alternating directions.
If you select the check box and set [Group (Same Pages)] for <Finishing> the specified number of print sets are output by page, and each page set is output in alternating directions.
Staple Position*
If you set [Staple] for <Finishing> you can specify the stapling position.
Booklet*
Saddle Stitch*
Opening Direction*
Store in Mail Box*
